boosted 01 accord makin VERY low power! HELP!!!
Old Apr 25, 2008 | 01:45 PM
S1n1SteR's Avatar
Default boosted 01 accord makin VERY low power! HELP!!!
i have an automatic f23a1 and making a mere 195hp to the wheel with 5lbs of boost! where did i go wrong?
have ported and polished head and a gude cam, a drag turbo kit with a custom 2.5 into 3.00inch exhaust with greddy's emanage ultimate.
could it be bcuz i have an auto tranny thats holding up? maybe get bigger injectors? more boost?
any n all help would be really appreciated!
Old Apr 25, 2008 | 01:48 PM
Schister66's Avatar
Man U FTW
Why did you tune on 5psi?? To me, that's a huge waste of time. The obvious things to me are the 2.5" restriction, the auto tranny and especially the eManage. Go with a real EMS and you'll have better luck.
List your setup and post your dyno graph...that will give us a lot better idea of what may be wrong.
Old Apr 25, 2008 | 01:51 PM
S1n1SteR's Avatar
Default Re: (Schister66)
how much would the tranny be holding back tho?
should i consider on getting fuel pump? maybe a better fuel pressure regulator? and also, what should be the spark plug heat range and the gap?
and only 5psi to make reliable and safe power without breaking anything
Old Apr 25, 2008 | 01:57 PM
morgan@synapse motorsport's Avatar
Default Re: (S1n1SteR)
2.5" exhaust isnt near restrictive at that level. what size injectors are you running you never stated. a fuel pressure regulator wont help you any.
there arent many ems options for the automatic users. dyno graph would be great.
Old Apr 25, 2008 | 02:07 PM
S1n1SteR's Avatar
Default Re: (mike@synapse motorsport)
stock injectors
Old Apr 25, 2008 | 02:28 PM
B20luda's Avatar
you're running 5psi.. on a SOHC vtec motor with a power robbing automatic, what do you expect??
Old Apr 25, 2008 | 02:32 PM
S1n1SteR's Avatar
Default Re: (B20luda)
yeah but 194???? i would be fine if it were 220-230 u knw?
Old Apr 25, 2008 | 03:06 PM
chimmike's Avatar
your expectations are way too high. IMO 195whp on an automatic at 5psi is actually pretty good.
Old Apr 25, 2008 | 03:18 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20luda &raquo;</TD></TR><TR><TD CLASS="quote">you're running 5psi.. on a SOHC vtec motor with a power robbing automatic, what do you expect?? </TD></TR></TABLE>
Lol...i have to agree
Old Apr 25, 2008 | 04:08 PM
notoriousB's Avatar
Default Re: (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">your expectations are way too high. IMO 195whp on an automatic at 5psi is actually pretty good.</TD></TR></TABLE>
I agree. The stock F23 only dyno at ~120ish WHP. You're doing pretty damned well on an auto at 5 psi.
S1n1SteR
Apr 27, 2008 05:48 PM
twotonecivic
Feb 4, 2007 12:44 PM
sony224422
Jan 8, 2007 03:58 PM
jayfowens
Jul 6, 2005 08:52 PM
turbodsm96
May 24, 2005 08:40 AM
