Replacing Chassis and engine harness in a 1991 std hatch
Old Apr 25, 2008 | 09:12 AM
McLovin's Avatar
Default Replacing Chassis and engine harness in a 1991 std hatch
I want to replace my chassis and engine harness in my 1991 civic std with a chassis and engine harness from a obd-0 mpfi car. My car is mpfi right now but the previous owned really chopped up both engine and chassis harnesse so i am having a ground issue somewhere.
I read that the only harness to use would be a 90-91 civic si chassis harness. would a crx harness work also in a hatch or are they different?
Thanks in advance
Old Apr 25, 2008 | 09:57 AM
thevtecnician's Avatar
Default Re: Replacing Chassis and engine harness in a 1991 std hatch (McLovin)
Yah use one from a hatch. The crx is a little shorter. you could use one from 88-89 hatch also but you would have to re-pin some things. It would be much easier to use a 90-91 harness as you said. Also, make sure you get the dash harness that goes with the rest of the mpfi chassis harness.
boostedb20z
Jul 23, 2009 08:13 PM
thorclark
Apr 29, 2008 07:39 PM
HatchBox
Northeast (Sales)
Mar 11, 2006 02:08 PM
Josue
Oct 2, 2005 10:01 AM
Keith P
Mar 8, 2005 06:57 AM
