Stripped suspension nut...Cant find a new one
I am doing a rear disk swap on my Ej1 and the nut that is inside the subframe is stripped....This nut has been giving me problems since i started the swap... Here is a picture and ill explain more
I need the nut that bolt #27 goes in to. (bolt 27 that goes through washer #31 in to the subframe of the car) This nut is inside the subframe itself...I believe this is where you adjust your toe in/out on the rear of the car...I cant seem to find this nut anywhere online. i looked on hondapartsdeals.com and i cants find it...
HELP PLEASE!!!
EDIT: PICTURE WONT SHOW UP...LET ME TRY TO FIND ANOTHER DIAGRAM
Modified by LSej1 at 2:48 PM 4/25/2008
HELP PLEASE!!!
nope didnt help...i got it back on...rear disk swap is about done...only bitch now is the e-brake cables....anyone know if a 93 hatch e-brake cable will fit a 95 coupe?
.inbou
May 17, 2010 08:15 AM
