melt down after 40 miles??
Old Apr 25, 2008 | 07:27 AM
Rene M's Avatar
Default melt down after 40 miles??
So my track motor melted down after only 40 miles on the track.This was Gils motor i bought from him and tuned with a s300 on the dyno and had pulled out a massive amount of timing from the Gil map to make it reliable.
There is no sign of detonation on any other cyl or plug just this one.
So wtf?
http://www2.snapfish.com/thumb...97634
Old Apr 25, 2008 | 07:34 AM
CW-ITR's Avatar
Default Re: melt down after 40 miles?? (Rene M)
Hope you find out the root cause of this.
Old Apr 25, 2008 | 07:43 AM
mtny's Avatar
Default Re: melt down after 40 miles?? (CW-ITR)
Oh man.
Good luck dude.
Old Apr 25, 2008 | 07:57 AM
RTW DC2R's Avatar
injector problem?
Old Apr 25, 2008 | 08:02 AM
GO-FIGHT-KILL's Avatar
DAMN.
Old Apr 25, 2008 | 09:14 AM
coolhandluke's Avatar
Default Re: (GO-FIGHT-KILL)
Dang, you have the worst luck. Was this datalogged?
Old Apr 25, 2008 | 09:18 AM
dyingwish's Avatar
You said you pulled lots of timing to make it more reliable, from Gils previous map....what data did you use to decide this? If that was the only cylinder that sustained damage, I'd think clogged injector. Have all of them flow tested....just to rule that out.
See this scares me a bit...I just started my freshly rebuilt track motor.....I hope I have no isses.
Old Apr 25, 2008 | 09:25 AM
CW-ITR's Avatar
Default Re: melt down after 40 miles?? (dyingwish)
Like other already mentioned, "no sign of detonation on any other cyl or plug just this one" usually means that perticular injector suddently decided to give up and starved that cylinder.
Old Apr 25, 2008 | 09:50 AM
mtny's Avatar
That motor was sick too.
Old Apr 25, 2008 | 10:08 AM
crx(gator)'s Avatar
Default Re: (coolhandluke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolhandluke &raquo;</TD></TR><TR><TD CLASS="quote">Dang, you have the worst luck. </TD></TR></TABLE>
Old Apr 25, 2008 | 11:27 AM
Austin's Avatar
My first though would be a bad/clogged injector.
Old Apr 25, 2008 | 12:23 PM
JjuuN R's Avatar
Default Re: melt down after 40 miles?? (Austin)
Yup same, starved of fuel...
Old Apr 25, 2008 | 04:55 PM
HotboxedTypeR's Avatar
Is there any warning signs to tell if or when an injector might clog like this? Can this happen to any motor? Seeing that kinda scares me.
Old Apr 25, 2008 | 06:08 PM
climb_on's Avatar
Default Re: melt down after 40 miles?? (HotboxedTypeR)
man rene that really is a bummer, watching that head (which for the recorde looks good for reuse) come off and see that piston really put a on my face.
like the others have said this is very likely a faulty injector should get them tested before you use them again. if you need any help working on it let me know!
this is Kevin's friend Cassio by the way.
Old Apr 25, 2008 | 08:38 PM
00-501itrspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotboxedTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Is there any warning signs to tell if or when an injector might clog like this? Can this happen to any motor? Seeing that kinda scares me. </TD></TR></TABLE>
ummm just guessing , but id say a lack of power would be a clue .
this sucks ,
Old Apr 25, 2008 | 10:10 PM
stealth50k's Avatar
Sell those injectors and get better ones or get them cleaned professionally.
Old Apr 25, 2008 | 11:27 PM
mtber's Avatar
Default Re: (stealth50k)
What did the plugs look like ?
What fuel were you running ?
Did you move the distributor after the car was tuned ?
Did you monitor the air fuel ratios with a wideband ?
Swapping a motor & ecu from one vehicle to another doesn't exactly mean that the tune isn't going to change. Voltage & other variances do exist between cars which will throw your tune off.
Old Apr 26, 2008 | 11:59 AM
Rene M's Avatar
Default Re: (mtber)
Well....
I inj failed! new set of RC 370's.
the flow test is 70 % off on the #3 cyl.
Old Apr 26, 2008 | 12:35 PM
Thrizzle's Avatar
* B A N N E D *
Default Re: (Rene M)
dang.. that sucks.. cyl #3 usually runs the hottest out of all too.
Old Apr 28, 2008 | 08:49 PM
climb_on's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">Well....
the flow test is 70 % off on the #3 cyl. </TD></TR></TABLE>
so our suspisions were correct thats a bummer. like i said before let if you need some help putting it back together let me know! i would like to sound like im being nice but your shop is just too cool, and working on the race R kinda puts the cherry on top.
cassio
Old Apr 29, 2008 | 10:41 AM
GUILOTINE's Avatar
Kill Gil
Brand new ******* injectors too. I'm sorry Rene....
Old Apr 29, 2008 | 10:56 AM
Dave_B's Avatar
Default Re: (GUILOTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">Brand new ******* injectors too. I'm sorry Rene....</TD></TR></TABLE>
If brand new, can the manufacturer be faulted?
Old Apr 29, 2008 | 11:05 AM
RTW DC2R's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
If brand new, can the manufacturer be faulted?</TD></TR></TABLE>
wondering that myself. im sure there is some kind of disclaimer on RC's website explaining this sort of situation. Im too lazy to look.
Old Apr 29, 2008 | 12:37 PM
GUILOTINE's Avatar
Kill Gil
From my experience, all manufacturers always find a way to weasel their way out of paying for anything. Claiming there products come with no implied warranty. Weak.
Davidls
May 8, 2010 04:13 PM
bluesi07
Honda Civic (2006 - 2015)
Apr 22, 2007 05:10 PM
Chunty Butt Kevin
Mar 23, 2005 09:36 PM
spartu5
Aug 2, 2003 01:20 AM
BoostedH23a1
Jun 5, 2003 03:41 AM
