Transmission Fluid Question
Old Apr 25, 2008 | 06:49 AM
shock_n_awe07's Avatar
Default Transmission Fluid Question
I have a 2000 Honda Accord V6 vtech with 160,000 miles and running good. The problem is I checked my automatic transmission fluid and it is cloudy and muddy. I haven't had any problems with the transmission but don't need any either. This is the original transmission. So I took it to the Jiffy Lube and they said that they would not do a Tranny Flush on a car with over 90,000 miles. If they did it might start to slip. A local transmission shop said they could drain half of the fluid out and then refill it. I've also read that the best thing to do is nothing at all.
What should I do or not do?
Modified by shock_n_awe07 at 8:27 AM 4/25/2008
Old Apr 25, 2008 | 08:22 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Transmission Fluid Question (shock_n_awe07)
drain and fill a couple times with Honda ATF.
those transmissions are known to have problems.
ZekeZG
Apr 5, 2016 01:24 PM
gauravsoni00
17
Sep 2, 2013 04:59 AM
RS250 Chester
Dec 12, 2012 12:46 PM
HondaAficionado
Transmission & Drivetrain
Jun 11, 2009 12:14 AM
gshock
Sep 10, 2008 01:35 PM
