can the thrust bearing washer fall out?
Old Apr 25, 2008 | 06:13 AM
teal_dx's Avatar
Default can the thrust bearing washer fall out?
I have a d15b7 complete block minus head in my garage. someone is coming to buy it tomorrow. every once in a while I spray the cyl walls w/ wd40 and spin the crank a few times to keep it from getting too dry & starting to rust.
Well I was just spinning the crank last night and I heard a "clink" from the bottom of the motor. Is there any way that could have been a thrust bearing/washer falling out? Can they some loose & fall out from spinning the motor the wrong way? I was turning the crank in both directions.
I can't think of anything else that would have make a "clink" noise from the bottom of the motor.
Old Apr 25, 2008 | 06:54 AM
Lubo_25's Avatar
Default Re: can the thrust bearing washer fall out? (teal_dx)
a thrust washer cannot fall out of its recess...the main cap holds it from spinning in any direction
Old Apr 25, 2008 | 12:21 PM
alexsracing's Avatar
unless they were installed backwards which I have seen, I removed a oil pan on a running motor with crank in and out play when you push and pull on the ecrank pully.
it had 1 of the thrust bearing in the pan (in the shape of a U) and the other paper thin, even the girtle was damaged where the thrust washers are susposed to be kept from spining
Old Apr 25, 2008 | 09:10 PM
Lubo_25's Avatar
Default Re: (alexsracing)
now that would be a case on its own...a truly stupid error
Old Apr 26, 2008 | 06:57 PM
lady ceri_us's Avatar
Default Re: (Lubo_25)
JJ291
Honda Civic (2001 - 2005)
Sep 15, 2013 06:30 PM
s032105k
Dec 28, 2010 06:17 PM
takumi604
Mar 26, 2005 09:23 PM
Muckman
May 17, 2004 08:33 PM
HybridBert
22
May 11, 2004 03:27 PM
