SRS light won't turn off.
Old Jul 12, 2002 | 12:50 PM
accord ex's Avatar
Default SRS light won't turn off.
The SRS lights won't turn off on my 95 accord ex, but i replaced the two airbags, and they are still on. Anyone knows whats wrong with it.
Thanks.
Old Jul 12, 2002 | 12:52 PM
carolinaACCORD's Avatar
Default Re: SRS light won't turn off. (accord ex)
check fuse and wiring.
Old Jul 12, 2002 | 01:06 PM
unltdacc12's Avatar
was the car in an accident?? if so the sensors and possibly the airbag module may need replacing.... did you unplug the batt when you installed the airbags??
Old Jul 12, 2002 | 01:35 PM
YeuEmMaiMai's Avatar
pull the codes
Old Jul 12, 2002 | 02:59 PM
bill-71SS's Avatar
re-set ecm, if lite comes back on, replace the controller, it is up front on your console. 95 controllers where re-called for this problem, but car has to be within warranty guidelines. There is a re-set plug on the left side under dash, but you have to know how to reset it, check your manuals, it may be in there.
Old Jul 12, 2002 | 03:03 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: SRS light won't turn off. (bill-71SS)
I know this is a very common problem, mine is no different.
It can be fixed at the dealership, I forget how costly it is... if it's under warranty all the better.
mortificationrock
Mar 23, 2011 05:24 AM
sneaks
Jul 1, 2010 04:54 AM
sandturtle
Apr 15, 2008 07:42 PM
technine
May 24, 2006 04:17 PM
accord ex
Jul 22, 2002 09:11 AM
