Adjusting/Replacing Alternator Belt
Old Apr 24, 2008 | 10:02 PM
iOn's Avatar
iOn
Default Adjusting/Replacing Alternator Belt
So my '00 Civic DX has been whining/squealing in a high pitched sound for the past 2-3 months and I'm finally fed up with it. I'm pretty sure it's the alternator belt because it happens when I'm almost stopping, turn on my headlights/AC/etc. Sometimes if I rev my engine it will go away for a little bit, but it always comes back... I'm guessing the belt is loose.
How to I tighten and/or replace the alternator belt? Is it pretty easy to do...?
Old Apr 24, 2008 | 11:16 PM
immajackuup's Avatar
Default Re: Adjusting/Replacing Alternator Belt (iOn)
most likely your belt is too tight,because mine was tight and it made that noise u talking about.
it does it a little but not much as before, i think that my alternator belt because i only loosen ac belt.
Old Apr 27, 2008 | 06:14 PM
iOn's Avatar
iOn
Too tight eh? I assumed it was loose and can't get any "grip" which causes the squealing...
Any other help?
Old Apr 27, 2008 | 07:21 PM
obuhmyuh's Avatar
Default Re: (iOn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iOn &raquo;</TD></TR><TR><TD CLASS="quote">Too tight eh? I assumed it was loose and can't get any "grip" which causes the squealing...
Any other help?</TD></TR></TABLE>
its loose, its really hard to over-tighten it. you need to loosen 2 bolts on the alternator bracket and get a crow-bar and slide the alternator toward the steering wheel and tighten those bolts. when ur done a little bar of soap on the underside will lubricate it and stop it from squeeling
good luck
Old Apr 28, 2008 | 09:17 PM
iOn's Avatar
iOn
What is the crowbar used for?
Old Apr 28, 2008 | 09:21 PM
BEE1's Avatar
Default Re: (iOn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iOn &raquo;</TD></TR><TR><TD CLASS="quote">What is the crowbar used for?</TD></TR></TABLE>
to move the alternator.
Old Apr 29, 2008 | 09:03 AM
obuhmyuh's Avatar
Default Re: (iOn)
crowbar=prybar, use it to pry the alternator away from head, thus creating tension on the belt (tightening it). its the only way to get it tight enough, it would take super human effort by hand.
M.D. CIVIC
10
Feb 23, 2010 06:47 PM
higgunscrx
Jun 15, 2006 05:11 PM
oxSLEEPERxo
Mar 20, 2005 11:23 AM
blackccoupe
Sep 23, 2003 03:00 PM
andrewasf77
Jul 10, 2003 08:24 PM
