fs/ft al- 90 crx si b18a1 swap many extras!
got a 90 crx si, wire tuck, firewall done in silver heat wrap paper, rear discs, sunroof, weaponr coilovers on tokico illuminas, camber kits front and rear, sparco torino seats, b18a1 with b18b p75 intake manifold engine and tranny all silver based and cleared before installation and valve cover candy red, you have to see it to understand, pics dont do justice, billet mounts, blox adjustable cam gears, gsr fuel rail and injectors and no injector resistor box, msd ignition with wires and external coil, CTR N1 crank pulley, battery relocated to trunk, it has a 93 ys1 tranny, exedy stage 1 clutch, fidanza 8.5 flywheel, itr header(has dent) full 2.5 exhaust from header back, hks high power muffler, jdm amber corners, clear bumper lights, usdm tails, all tinted, yellow 89 prelude fog lights, brand new axles, also has black with polished lip rota d2's on it now but will come with steelies unless an offer is made for the d2's, ac removed, but still have all parts, and car has a factory manual steering rack in it, radiator replaced about 6 months ago, new thermostat. i also stil have the original si 1.6 d series drive train, engine tranny, etc., also have spare b18 valve cover and two spare intake manifolds. also has a WORKING 2000 gsr gauge cluster, skunk2 weighted shift ****, shortened factory teg shifter, has a factory acura cd player, mb quart components in the doors.
the bad- needs a driver fender, has a few wrinkles in it, car is black primer, has a small crease in passenger door, and a small dent in the rear quarter right behind the driver door. interior is in really good shape for a 90, no cracks or stains, the only bad part is the usual a/c crack, and is three small pulls tears in the door panel on the driver side that you wouldnt notice unless you were looking for them, and it needs a drivers window regulator, it works fine you just have to help it up, passenger is brand new, i will include one if the price is right.
it is good shape aside from the body work, i drive it everyday to work and have had it on the track only once. it ran a 15.2 on some crappy tires and runs it consistently. i since have put stickier tires on it but havent been back to the track, but i feel that if it hooks it will run somewhere in the neigborhood of a 14.7.
looking for $3500.00, or $4200.00 with wheels and tires. or am looking for a trade for a eg hatch, ek hatch, or db or dc. must be 5 speed. make offer, need gone
PENDING SALE
Modified by brxtacy at 7:39 AM 4/25/2008
Modified by brxtacy at 12:34 AM 4/26/2008
Modified by brxtacy at 3:34 PM 4/27/2008
PENDING SALE
Walshie
Oct 15, 2008 09:10 AM
