Parada Spec 2 Question
Old Apr 24, 2008 | 08:45 PM
lxk199's Avatar
Default Parada Spec 2 Question
Quick question about the Parada Spec 2, because my brain doesn't seem to be working tonight. The Spec 2's don't have directional markings on them, but they do have the stamp that says "this side outwards". My question is this: If you mount them all with the "this side out" facing out (which I assume you would), then the grooves in the tread will point different directions (one side will point forwards, the other backwards). Is this OK, or should they be mounted with the grooves pointing the same direction? I guess it should be OK since they aren't directional, right?
Old Apr 25, 2008 | 11:49 AM
purejdmek9's Avatar
right they aren't directional so it doesn't matter if the markings are headed the same direction
HackeN
Jan 29, 2006 12:00 PM
Mentat Ghola
Feb 29, 2004 02:39 PM
