Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Factory Sub Replacement
Old Apr 24, 2008 | 06:32 PM
claytucc3's Avatar
Default Factory Sub Replacement
Has anyone replaced their factory sub with an after market one, while still using the factory amp?
Old Apr 24, 2008 | 06:39 PM
RICO_'s Avatar
NO MERCY!
Default Re: Factory Sub Replacement (claytucc3)
Factory amp isn't powerful enough to power most aftermarket subs. If you're going to replace the sub then you might as well get a small aftermarket amp to go along with it.
Old Apr 24, 2008 | 08:47 PM
johnnycivic66's Avatar
I'll agree with Rico, but I was wondering if anyone might replace the 8inch with an after market sub of the same size, and retained the mounting?
Old Apr 25, 2008 | 09:42 PM
RICO_'s Avatar
NO MERCY!
Default Re: Factory Sub Replacement (johnnycivic66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnnycivic66 &raquo;</TD></TR><TR><TD CLASS="quote">I'll agree with Rico, but I was wondering if anyone might replace the 8inch with an after market sub of the same size, and retained the mounting?</TD></TR></TABLE>
If you do that you better make sure it's a free-air sub. Free air subs (like the stock one) do not require an enclosure to function.
However most aftermarket subs are NOT free-air and DO require an enclosure.....in that case it wouldn't sound very good to put a sub like that in the stock location. You would get very very little if not any bass out of the sub.
Old Apr 26, 2008 | 04:15 PM
2008fijibluesi's Avatar
Default Re: Factory Sub Replacement (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">
However most aftermarket subs are NOT free-air and DO require an enclosure.....in that case it wouldn't sound very good to put a sub like that in the stock location. You would get very very little if not any bass out of the sub. </TD></TR></TABLE>
Mostly true...but a lot of 8" subs are designed to replace OEM subs. Not too many people put 8" subs in a box. Most manufacturers realize that people purchasing 8" (and anything smaller than 10") subs are probably looking to replace an OEM sub in its original location.
Old Apr 26, 2008 | 04:33 PM
RICO_'s Avatar
NO MERCY!
Default Re: Factory Sub Replacement (2008fijibluesi)
They COULD replace OEM subs....but unless it's designed for free air performance you won't get alot out of it and could ultimately prematurely damage the sub. Free air subs are designed a little differently than enclosure subs.
JL Audio used to make a free air sub but they discontinued it.
Kicker Comps however do function pretty good as a free air sub. There are probably a few others out there that can do the trick, but the Comps are the only ones that I have seen in action in a vehicle as both free air or enclosed.
Modified by RICO_ at 7:39 PM 4/26/2008
Old Apr 26, 2008 | 04:54 PM
true true
Old Apr 26, 2008 | 09:04 PM
matt360's Avatar
8" Image Dynamics IDQ
Old Apr 30, 2008 | 03:02 AM
claytucc3's Avatar
Default Re: Factory Sub Replacement (matt360)
Is that speaker a direct replacement and work with the amp?
Old May 2, 2008 | 04:59 PM
claytucc3's Avatar
Anyone?
Old May 6, 2008 | 12:07 PM
claytucc3's Avatar
The Kicker and the Dynamics will need an aftermarket sub correct?
Old May 6, 2008 | 05:26 PM
RICO_'s Avatar
NO MERCY!
Default Re: (claytucc3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by claytucc3 &raquo;</TD></TR><TR><TD CLASS="quote">The Kicker and the Dynamics will need an aftermarket sub correct?</TD></TR></TABLE>
You mean amp? Yes.
teknoracing
Audio / Security / Video
30
Jun 7, 2006 03:42 PM
thelonerangers
27
Mar 27, 2006 12:44 PM
wessieball
Oct 9, 2004 07:49 AM
ctownintegra
17
Jul 20, 2004 10:18 PM
EVIL_AWD
13
Jul 18, 2003 12:14 PM
