Oil Leak? on D16z6
I need help... something in my car is leaking at first i thought it was the valve cover then i checked it again its not then i checked the head gasket its not it either. THEN, i finally found it.. when i changed oil today. I think it is the gasket between the transmission and the engine itself... but i'm wondering if there is really a gasket or i just have to use those permatex gasket sealer so it can stop leaking... i think the gap opened bcuz whenever i pull into my garage i always scrape and i feel the scrape...........
sorry... its kinda hard for me 2 explain bcuz im not really a mechanic.. im just trying to maintain my car...
thank you
thank you
There's no fluids where the trans and engine meet its just a dry space with the clutch/flexplate ect. (auto). If oil is coming down along that edge though its probably either your distributor o-ring or vtec soleniod gasket. Or by long short your input shaft seal/bearing (what ever it is) is bad and it going down through there and out.
SIRIUS VTEC
19
Jul 10, 2007 04:35 PM
95autocivic
Jan 9, 2006 06:00 PM
common, cover, d16z6, distribuator, distributor, gasket, honda, leak, leaking, leaks, oil, ring, tranny, transmission, valve
