Will a 2.5" exhaust flange bolt up to a stock cat flange???
Old Jul 12, 2002 | 12:01 PM
BSQ's Avatar
BSQ
Default Will a 2.5" exhaust flange bolt up to a stock cat flange???
I just purchased a new Type-R cat-back exhaust and I will be installing it on my '94 GS-R. The B-pipe needs to be extended ~3" to mount to the stock cat. In the near future (3-9 months) I will be installing either a JDM Type-R 4-1 header or a DC JDM 4-1 header with a 2.5" flange, so I will also be going with a 2.5" hi-flow cat. So I figured will I'm extending the B-pipe I might as well weld on the 2.5" flange. So will a 2.5" exhaust flange bolt up to a stock cat flange?
Here is a picture of a stock cat and 2.5" hi-flow cat (image borrowed from http://www.sandmracing.com ):
Here is a picture of the 2.5" exhaust flange I'm referring to (image borrowed from http://www.sandmracing.com ):
D or Aleph, didn't you have a picture on your website which showed the 2.5" exhaust flange welded onto the stock exhaust pipe???
[Modified by BSQ, 4:02 PM 7/12/2002]
Reid's Avatar
Global Moderator
Default Re: Will a 2.5" exhaust flange bolt up to a stock cat flange??? (BSQ)
Yes, it'll bolt up.
It'll also be a nice bottleneck.
Old Jul 12, 2002 | 12:05 PM
BSQ's Avatar
BSQ
Default Re: Will a 2.5" exhaust flange bolt up to a stock cat flange??? (Reid)
Can you clarify? What will be a nice bottleneck???
Old Jul 12, 2002 | 12:08 PM
Willard's Avatar
Yes... the 3 bolt flange has the same dims. as the stock stuff.
Willis
[Modified by Willard, 4:09 PM 7/12/2002]
Old Jul 12, 2002 | 12:09 PM
Reid's Avatar
Global Moderator
The outer flange is the same, so it'll bolt up.
But the 2.5" hole will be mated up to a stock ITR catback.
That will create a bottleneck. Bottlenecks are always a bad thing.
Old Jul 13, 2002 | 11:48 PM
VrInteg's Avatar
New User
Are you sure??
When I tried today to bolt up my ITR catback with the stock cat, it did not bolt on at all. Do the years of the ITR catback make a difference?
Btw, I drive a 95 Gsr.
Forgot to mention, I am using a USDM DC 4-2-1 and is there a j-spec type r b-pipe?
[Modified by VrInteg, 8:55 AM 7/14/2002]
93(Civic)EG6
Oct 2, 2007 08:21 PM
shutta
Aug 21, 2006 01:42 PM
MOVE OVER
Aug 10, 2006 03:43 PM
slowacura
Oct 13, 2002 07:30 AM
vtecnik
Sep 1, 2002 09:31 PM
