Oil in one intake/head port what's the cause?
Old Apr 24, 2008 | 03:03 PM
Dom_GsR's Avatar
Default Oil in one intake/head port what's the cause?
Hi,
Yesterday, I removed my intake manifold to change it for a new one. I noticed some oil on the left intake port. Also, there was oil in the same head intake port. I put my finger in the port all the way to the valve and I could feel a little pool of oil on the valve. The intake piping was clean/dry so It's not coming from the turbo. What could it be? Valve seal?
Thanks for your help everyone
Old Apr 24, 2008 | 03:06 PM
1992Si's Avatar
Valve seals are leaking.
If you have to ask your better off paying to have them replaced.
Well, you removed the intake so may be you'll want to tackle this. It's a big job.
Old Apr 24, 2008 | 03:09 PM
Dom_GsR's Avatar
Default Re: (1992Si)
wow thanks for your help sir!
I will have it done tomorow don't want to risk dropping a valve!
Old Apr 25, 2008 | 02:22 PM
vtecb18c's Avatar
Default Re: Oil in one intake/head port what's the cause? (Dom_GsR)
si is dead on. either its your valve seals or valve guides. just went through the same problem
Old Apr 25, 2008 | 07:56 PM
slowcivic2k's Avatar
Default Re: Oil in one intake/head port what's the cause? (vtecb18c)
Valve seal probably failed because the guide mushroomed out, allowing the valve to **** itself, disturbing the seal. replace the guides, seals, and inspect the valves.
Replacing the seal will stop it for a little while, but you have to also remember, boost is trying to push that seal open, so it will only function partially the way it was supposed to. Vacuum in the manifold helps keep them tight. Pressure will blow them open.
blackeg
Aug 27, 2013 06:51 PM
jdmeg6fan
May 15, 2013 06:27 PM
jvk
Aug 21, 2008 09:59 AM
thomas188
Oct 7, 2006 05:28 PM
