OBD0 2 OBD1 Distributor bolt up problem
Old Apr 24, 2008 | 02:25 PM
BlakeJ53's Avatar
Default OBD0 2 OBD1 Distributor bolt up problem
I have a 90 crx hf with a D16A6 motor in it and I am converting to OBD1 for better tunning options I have swaped everything else but the dizzy becuase it wont bolt up all the way, one leg is off in the middle of nowhere. What do I do? Please help.
Jordan
Old Apr 24, 2008 | 03:21 PM
Crx Jimmy's Avatar
Default Re: OBD0 2 OBD1 Distributor bolt up problem (BlakeJ53)
dont use that leg, just use 2 bolts
Old Apr 24, 2008 | 03:23 PM
BlakeJ53's Avatar
Default Re: OBD0 2 OBD1 Distributor bolt up problem (Crx Jimmy)
does it have to line up a sertin way ? Or does it just go on any witch way?
Old Apr 24, 2008 | 09:21 PM
BlakeJ53's Avatar
bump anyone
Old Apr 24, 2008 | 09:23 PM
mario_pic's Avatar
try a 93 civic non vtec dizzy the y8 head fits the a6 dizzy and u only need to move one plug a head so what im thinking u can use a obd1 dizzy off a d15b7 or b8
Old Apr 24, 2008 | 10:58 PM
BlakeJ53's Avatar
Default Re: OBD0 2 OBD1 Distributor bolt up problem (mario_pic)
I have a OBD1 Non vtec dizzy, but it doesnt fit properly.
Old Apr 25, 2008 | 04:30 PM
BlakeJ53's Avatar
Anyone?
Old Apr 26, 2008 | 03:48 PM
BlakeJ53's Avatar
help please
Old Apr 26, 2008 | 05:16 PM
welfarepc's Avatar
run it with 2 bolts like said above
Old Apr 26, 2008 | 09:53 PM
SoCal B18b 4dr's Avatar
i always just take out my dremel and make the hole bigger on the top leg or u could cut the leg off just below the bolt hole and use a washer to secure it. as far as where it should be, just leave it loose enough to move back and fourth and start the car, then move it to where the car seems to run the best, tighten the bolt up, and go for a test drive. if its too far advanced then u will get very bad low end, possibly even a bit of a studder, but good top end, and oposite for too far retarded. so just play around with it until u get find the middle of the road where both low end and high end run smoothly.
Red_ED8
Feb 4, 2010 06:37 AM
crxdonwon
Feb 19, 2009 05:53 AM
patric8332
Dec 10, 2007 08:49 AM
ABK
May 6, 2004 07:48 AM
88crxsi89
Mar 14, 2003 06:38 PM
