96-98 civic harness for 00 itr swap. what wires to add?
parts...
00 civic hatch
96-98 civic wiring harness
00 itr swap
1. do i need to add any wires to this harness for it to work with an 00 itr engine?
2. could i just get obd-1 plugs and rearrange the wires from the harness to the corresponding spots in the obd-1 plugs so i dont have to buy the obd2->obd1 jumper?
00 civic hatch
00 itr swap
parts...
00 civic hatch
00 itr swap
00 civic hatch
00 itr swap
when using a 00 car with 00 swap...
keep ur stock harness...and add the wires...
obd2 and obd2.b is different ecu plugs
u would have to rewire everything if you changed all your plugs... get the converter... and stay with obd-2, use your civic harness and add vtec wires.
I can email you the 99-00 ecu pinouts if you need them.
But if you can get the 99-00 Si harness and call it a day. (echo in here)
crackerjacker006
Jul 17, 2005 07:31 PM
GeorgeJetson
Sep 25, 2003 12:11 AM
