B Series Parts F/S
90-93 B series Axle passenger 50$
Da halfshaft $40
Obd0 B16a Distributor $120
Obd 0 Pr3 Ecu Virgin Not Chipped $150
B series LS Shift Linkage $80
1994 Del Sol b16 Intake Manifold 50$
JG B Series Oem Ported TB 80$
Nuespeed Race Springs (Yellow) 88-91 Honda Crx Ef9 hatch 60$
3 used clean Eagle Esp B18/B20 Rods $ Shoot an Offer
Check Point CAI 2 piece Polished with Filter $30 + Shp. DA/CRX/EF
99 GSR Hydro Halfshaft $40 + Shp
99 B20B Jdm Bare block with main caps Hairline cracked # 2 Sleeve from top halfwaydown. Perfect sleeve block legit $50 + Shp.
b18a block sleeved by RS machine 86mm RACE BLOCK NEEDS TO BORE OVER .25 to 86.25mm w/ original main caps Perfect condition $200 OBO
1991 B18a Crank Slight rust in some journals Needs a Balance and Polish
60$
P28 ECU needs hondata bridge soldered on good for s100 or s200 $50
Modified by JakeSpec at 8:55 AM 4/28/2008
Modified by JakeSpec at 8:57 AM 4/28/2008
Da halfshaft $40
60$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leeftwisted_db8 »</TD></TR><TR><TD CLASS="quote">free bump
thanks!
</TD></TR></TABLE>thanks!
