01 Prelude revs itself
Old Apr 24, 2008 | 07:53 AM
bizzlekip's Avatar
Default 01 Prelude revs itself
I just rebuilt the head on my 01 Prelude and I just got it running. It automaticly revs itself from 1500- 4300rpm at idle. I sprayed some carb cleaner by all the vacuum lines looking for leaks and found none until I went by where the IM meets the head. It appears my IM gasket didnt seal in that spot.... I also got a code for both Throttle Position sensor and Vehicle speed sensor. Is is possible the codes are from the leak or is it more likely a TPS issue?
Old Apr 24, 2008 | 10:16 AM
mattsnooz's Avatar
Default Re: 01 Prelude revs itself (bizzlekip)
Your TPS might need adjusting. You'll have to check its voltage
Your leak should be causeing that wierd reving reving. If you don't feel like pulling it all apart, degrease, and alcohol swab the area. Let dry, and than use high heat resistant silicone sealent.
(I had a slight IM leak after I pulled it so I pussied out and used grey silicone sealent (good for 700 I think) and its been fine for 2 years. No leak at all, and doesn't brake down from heat (resulting in smells and falling off).
Vss could be an indipendent problem. Personally I don't know of the other two (throttle posistion sensor, intake manifold leak) issues resulting in a vss failure. If your 5th gen is like mine your VSS is ontop of your tranny I think. Maybe check the wires/connector/contactor. You might have missed something simple.
heato
Mar 30, 2012 07:08 PM
r6racer5394
Jun 24, 2009 11:07 AM
The Sign Guy
Jan 14, 2009 07:30 AM
heatmiser8883
Apr 18, 2005 10:24 PM
cec92lude
Oct 5, 2003 06:40 AM
