Running on 1 cylinder!!!!! Please Help!!!!
Old Jul 12, 2002 | 11:27 AM
fire7882's Avatar
Default Running on 1 cylinder!!!!! Please Help!!!!
After the first gen b16a swap, i'm running on 1 cylinder. The only operating cylinder is the second one from the left. I have compression #s of 205,207, 208,206 and every cylinder is reciving fire. The only thing i can figure is fuel. Are the fuel injector wires wired differently or could my injectors be cloged. Any other ideas. Here is a pic of the injector wires.
[Modified by fire7882, 3:28 PM 7/12/2002]
Old Jul 12, 2002 | 11:30 AM
IntegD's Avatar
New User
Default Re: Running on 1 cylinder!!!!! Please Help!!!! (fire7882)
If your compression comes out that much in each cylinder, how do you know that you are running on one cylinder? If the car starts and runs, just runs like ****, then it probably is a fuel problem. I have never done the swap before, but I do remember someone saying that if you have an obd1 ecu then you need to make sure your injectors are obd1 as well, etc. etc. Good luck bud...
Spade's Avatar
Fuel.
Start with fuel filter.
Old Jul 12, 2002 | 12:16 PM
fire7882's Avatar
Default Re: Running on 1 cylinder!!!!! Please Help!!!! (Spade)
Only one header runner would get hot so i pulled the other 3 spark plugs and it ran the same. I have an obd1 chipped ecu and obd1 wireing harness and obd1 distributor. The fuel filter is new so i don't think that would be the problem. The spark plug wires are on the same as a b18a1. Do vtec and non vtec distributors fire differently???
Old Jul 12, 2002 | 12:24 PM
owen_the_soyboy's Avatar
fuel injectors are very very very commonly clogged.
clean them out with brake cleaner and add somem injector cleaner to the gas tank.
trust me, ask me how I know
Old Jul 12, 2002 | 12:25 PM
Default Re: Running on 1 cylinder!!!!! Please Help!!!! (owen_the_soyboy)
the fact you are only getting one cylinder running is the reason I say injectors... and its a common problem.
Old Jul 12, 2002 | 01:21 PM
fire7882's Avatar
Thanks, i'll check that out now.
[Modified by fire7882, 5:21 PM 7/12/2002]
Old Jul 12, 2002 | 01:23 PM
Audi A4's Avatar
owen what do u mean clean the injector out expain cuse im having a similar problem
Old Jul 12, 2002 | 01:53 PM
tooqwik1's Avatar
Default Re: Running on 1 cylinder!!!!! Please Help!!!! (DRAG lll INTEGRA)
what harness ar eu using?
Old Jul 12, 2002 | 01:59 PM
fire7882's Avatar
Default Re: Running on 1 cylinder!!!!! Please Help!!!! (tooqwik1)
95 ex usdm harness
Old Jul 12, 2002 | 06:36 PM
fire7882's Avatar
I got all 4 cylinders running now. It was the injectors. They were stoped up. Thanks for the advice about using brake cleaner.
Old Jul 12, 2002 | 08:08 PM
CunninLynguist's Avatar
break cleanr...can you explain how you did it? my car is running like **** and i found out cylindr one is fukd up...i will just clean the injector and see if it helps...if not i will buy a new fuel filter..then i dont know whats next..any ideas?
Old Jul 12, 2002 | 08:59 PM
Audi A4's Avatar
Default Re: Running on 1 cylinder!!!!! Please Help!!!! (Lynx02)
any body bump
Old Jul 13, 2002 | 06:08 AM
fire7882's Avatar
When i cleaned the injectors, i filled a small cup with the brake cleaner. Then i let the injectors sit in the brake cleaner for 15 minutes. Then i got an air hose and pushed air through the injectors. Air would only travel in the opposite direction than normal fuel flow but it seemed to do the trick. I don't know if forcing air in the injectors can harm them, but it worked for me.
Old Jul 13, 2002 | 09:29 AM
Audi A4's Avatar
hmm i will have to try taht. hey fire im in henry co. wher are you?
Old Jul 13, 2002 | 01:41 PM
fire7882's Avatar
I'm a student at Georgia Tech. I'll be living in Vinings on august 1. My hometown is Swainsboro, GA and i'm currently working in Gainsville. What track does everyone go to in the atlanta area to get their 1/4 mile times?? I need to make a few runs.
Old Jul 13, 2002 | 06:24 PM
sweet, glad that trick solved your dilemma! My friend soaked his in brake cleaner for an hour then played around with a q-tip and more cleaner. I dunno if compressed air would be bad / forcing air thru them... but you'll find out soon enough. Cant imagine its so bad though.
again, glad it worked!
Old Jul 13, 2002 | 07:29 PM
Audi A4's Avatar
well fire ull probally run better times at renoylds. which is near macon kinda. but the nicer track is in commerce.
mouab18c1
Oct 1, 2012 08:40 AM
Rheg6
Nov 24, 2011 08:46 AM
b17 rolla
Jan 17, 2009 03:53 PM
Streetracer4life128
Jul 2, 2006 03:12 PM
VTHokie
May 16, 2003 01:31 PM
