Hondata IM gasket (or similar) question
Old Apr 23, 2008 | 11:54 PM
spAdam's Avatar
Loved
Community Favorite
Default Hondata IM gasket (or similar) question
Seems like this would be the place to ask since I'm running an itr im and my head is ported to match...
Does Hondata or another company make a c5 specific gasket, or do I just need to port match one of the b16 ones? I've always used the p73 when I've replaced it and it seems like I've seen a specific (isolating) one somewhere.
Gotta remove the manifold to do some stuff in the firewall area and thought I'd throw one in the mix while I'm in there... I also like the idea that its reusable.
Old Apr 24, 2008 | 03:00 AM
Cheeze's Avatar
Default Re: Hondata IM gasket (or similar) question (spAdam)
You should not have to port match the gasket. Just get the regular hondata one for the itr and you'll be fine.
Old Apr 24, 2008 | 07:39 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: Hondata IM gasket (Cheeze)
Ok, so there is a seperate one for itr then... they have b16a and b18c5 in the same box on their website, I thought that meant there was only one gasket.
Thanks
Old Apr 24, 2008 | 07:52 AM
Cheeze's Avatar
Default Re: Hondata IM gasket (spAdam)
B16a and B18c5 are the same casting
Old Apr 24, 2008 | 02:54 PM
spAdam's Avatar
Loved
Community Favorite
Itr manifolds have larger runners and the head is ported to match though.
Old Apr 25, 2008 | 03:30 AM
Racebrewer's Avatar
The Hondata gasket can be easily cut to match. It is a fairly soft plastic (Teflon?) and a sharp razor can be used.
Stainless steel studs, washers and nuts will also help fight heat transfer from the head.
I use Dow Corning Silicone Vacuum Grease (never hardens, good to 600 degrees) to seal it.
There is another gasket out there, that I believe is a harder, possibly phenolic material. Haven't seen one yet.
John
Old Apr 25, 2008 | 03:45 AM
RTW DC2R's Avatar
Default Re: Hondata IM gasket (Racebrewer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racebrewer &raquo;</TD></TR><TR><TD CLASS="quote">
John</TD></TR></TABLE>
i run the outlaw engineering kit
Old Apr 25, 2008 | 05:10 AM
D's Avatar
D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spAdam &raquo;</TD></TR><TR><TD CLASS="quote">Itr manifolds have larger runners and the head is ported to match though.</TD></TR></TABLE>
Factory ITR cylinder heads are NOT port matched to the intake manifold.
Old Apr 25, 2008 | 08:43 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: Hondata IM gasket (D)
^Interesting. I did not know that. Another ITR myth busted.
Thanks for the input guys!!
EnzoSpeed
Sep 17, 2005 07:17 PM
GSR4U2NV
11
May 22, 2005 08:04 PM
AlterEgo
Nov 9, 2004 03:04 PM
