TECH: F-Series Motor Guide
Old Jul 12, 2002 | 11:13 AM
Brandon's Avatar
Life is Suffering
Default TECH: F-Series Motor Guide
I am doing this as a chart to help out everyone as a one-stop resource. If you have any contributions, they would be welcome.
Old Jul 12, 2002 | 11:41 AM
Brandon's Avatar
Life is Suffering
Default Re: TECH: F-Series Motor Guide (accordvtec)
F22A1 SOHC non-vtec 8.8:1CR 125hp 137lb/ft 4G 90-93 USDM DX/LX 85b/95s
F22A4 SOHC non-vtec 8.8:1CR 130hp 142lb/ft 4G 90-91 USDM EX/SE 85b/95s
F22A6 SOHC non-vtec 8.8:1CR 140hp 142lb/ft 4G 92-93 USDM EX/SE 85b/95s
F22B1 SOHC vtec 8.8:1CR 145hp 147lb/ft 5G 94-97 USDM EX 85b/95s
F22B2 SOHC non-vtec 8.8:1CR 130hp 139lb/ft 5G 94-97 USDM DX/LX 85b/95s
F23A1 SOHC vtec 9.3:1CR 150hp 152lb/ft 6G 98-02 USDM EX/LX 86b/87s
F23A5 SOHC non-vtec 9.3:1CR 145hp 135lb/ft 6G 98-02 USDM DX 86b/87s
F20A DOHC non-vtec 9.5:1CR 150hp 137lb/ft 4G 90-93 JDM 2.0Si 85b/??s
F20B DOHC vtec ?.?:1CR 200hp ???lb/ft 6G 98-02 JDM SiR-T 85b/??s
F20C1 DOHC vtec 11.0:1CR 240hp 162lb/ft 1G NA-NA USDM S2000 87b/84s
F22B DOHC non-vtec 9.8:1CR 160hp 148lb/ft 4G NA-NA JDM Prelude Si 87b/??s
[Modified by F22turbo, 2:24 PM 8/21/2002]
Old Jul 12, 2002 | 11:44 AM
John's Avatar
New User
We need to include bore and stroke as well.
Old Jul 12, 2002 | 11:52 AM
Brandon's Avatar
Life is Suffering
Default Re: TECH: F-Series Motor Guide (DunReit)
done with that, now I just need some help with a few numbers, IM me if you guys can help. I believe I have every F-Series engine ever, so now it is just a matter of what is not correct or missing.
Old Jul 12, 2002 | 01:41 PM
psyphre's Avatar
DOHC non vtec 4G 92-96 JDM Prelude Si
Old Jul 12, 2002 | 05:23 PM
Gennady's Avatar
New User
Default Re: TECH: F-Series Motor Guide (psyphre)
F22A2??? 135hp?
Old Jul 12, 2002 | 06:31 PM
thenick's Avatar
Default Re: TECH: F-Series Motor Guide (Wont be beat)
JDM prelude SI DOHC F22
meet H23's destroked sister
Old Jul 12, 2002 | 06:49 PM
psyphre's Avatar
Default Re: TECH: F-Series Motor Guide (ixiblindixi)
yeah, i was just filling in the gen and year info.
Old Jul 12, 2002 | 07:31 PM
Brandon's Avatar
Life is Suffering
I left that out since it is not in an Accord.
Old Jul 12, 2002 | 10:31 PM
CmptchAV6's Avatar
but you included the S2000 motor and last time I checked it couldnt be put in an accord.
Old Jul 12, 2002 | 10:42 PM
Brandon's Avatar
Life is Suffering
Default Re: TECH: F-Series Motor Guide (CmptchAV6)
This is an F-Seires guide. And it can be put in an Accord, just not easily. If you hit an S2k hard enough it will be.
Old Jul 12, 2002 | 10:48 PM
CmptchAV6's Avatar
It is weird of all the series of motors honda has made the F series seems to be the most diverse comming in both SOHC and DOHC with or without VTEC the only other motors that come close to my knowledge is the ZC motors that came with SOHC/SOHC VTEC and DOHC.
Old Jul 12, 2002 | 11:07 PM
Brandon's Avatar
Life is Suffering
The B-Series is pretty diverse as well. But the F-Series ownz.
Old Jul 12, 2002 | 11:16 PM
CmptchAV6's Avatar
Not really to my knowledge the B series is just DOHC with or without VTEC
Old Jul 12, 2002 | 11:22 PM
Brandon's Avatar
Life is Suffering
There were SOHC versions early on in the Prelude, and I belive there was a SOHC VTEC motor in Japan
Old Jul 13, 2002 | 01:15 AM
TypeSH's Avatar
yea, the 4th gen lude S uses an F22 motor... not sure hte exact designation thou.
Old Jul 13, 2002 | 06:11 AM
Brandon's Avatar
Life is Suffering
Default Re: TECH: F-Series Motor Guide (TypeSH)
It is an F22A1, but has different numbers.
Old Jul 14, 2002 | 05:57 AM
Gennady's Avatar
New User
It cant be an F22A1 because the F22A1 makes 125hp, while the Prelude S engine makes 135hp. So I'm thinking its an F22A2, but thats just a guess.
Old Jul 14, 2002 | 07:56 AM
AccordCF4's Avatar
I have a question, is it possible to put a F20C in my JDM SIR-T as it is a F series motor??
Old Jul 14, 2002 | 08:52 AM
Nick M's Avatar
Default Re: TECH: F-Series Motor Guide (CF4 Owner)
no, not easily. It would probably be atleast a $10,000 job.
Old Jul 14, 2002 | 09:25 PM
AccordCF4's Avatar
Default Re: TECH: F-Series Motor Guide (HondaSport)
I just woundering if it is possible, and how difficult it would be...
cost would be a big problem of cause.
Old Jul 15, 2002 | 08:49 AM
Gennady's Avatar
New User
You would need a custom tranny, and the rest of the RWD to FWD configuration custom as well.
Old Jul 15, 2002 | 09:06 AM
Brandon's Avatar
Life is Suffering
He would have an excuse to use a Quaife sequential if he wants FWD.
Old Jul 15, 2002 | 11:11 AM
CmptchAV6's Avatar
well you must also remember the S2000 motor rotates clockwise where as the older honda 4 cylinders rotate counterclockwise including the H22 and the F22/23.
Old Jul 15, 2002 | 05:16 PM
Gennady's Avatar
New User
Hence the custom tranny.
