Will Acetone Mess Up Carbon Fiber???
Old Apr 23, 2008 | 09:47 PM
d_EG COUPE's Avatar
Default Will Acetone Mess Up Carbon Fiber???
i have a little over spray of paint on the duck bill and i was wondering if acetone mess it up... Should i juss try the rubbing alcohol?
Old Apr 23, 2008 | 10:11 PM
DCSportEJ1Civic's Avatar
Default Re: Will Acetone Mess Up Carbon Fiber??? (d_EG COUPE)
fine grit sand paper and the lay down some new clear coat. it should look brand new.
Old Apr 23, 2008 | 10:21 PM
jday1's Avatar
Default Re: Will Acetone Mess Up Carbon Fiber??? (DCSportEJ1Civic)
i have the fun pleasure of working with carbon all day long... acetone will mess up dry carbon but since there is a clear on top of the carbon the acetone is gonna damage the clear and not the carbon... try some rubbing compound of nu-finish to see if you can get the over spray off... depending on how much there really is... if it doesnt then i would say wet sand with 1000 or 1500 grit sand paper and go from there with the clear... wet sand the whole duck bill though just dont re-clear that over spray spots
Old Apr 23, 2008 | 10:27 PM
Eran's Avatar
HT White Ops
Default FV-QR
Man, you guys are looking way too into this.
Use a medium-grade clay bar.
Old Apr 23, 2008 | 10:29 PM
d_EG COUPE's Avatar
its not really over spray its like how should i say it if u spray paint in the air and 5 feet in front it barely hits so its like a bunch of little dots but thanx guys
Old Apr 23, 2008 | 10:33 PM
Eran's Avatar
HT White Ops
Default Re: (d_EG COUPE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d_EG COUPE &raquo;</TD></TR><TR><TD CLASS="quote">its not really over spray its like how should i say it if u spray paint in the air and 5 feet in front it barely hits so its like a bunch of little dots but thanx guys</TD></TR></TABLE>
Use a clay bar. No damage, no problems. Just results.
Old Apr 23, 2008 | 10:38 PM
d_EG COUPE's Avatar
Default Re: (Eran)
what kind of clay bar and where can i get it
Old Apr 23, 2008 | 10:46 PM
Eran's Avatar
HT White Ops
Default FV-QR
A Clay Magic Medium 200g bar would do you right. They're the red ones:
Coleman944
Paint and Body
10
Nov 1, 2013 10:52 PM
Sk33t-EM1
Jan 21, 2011 02:41 PM
angel949
Paint and Body
22
Oct 12, 2008 07:26 PM
importfanatic17
Sep 4, 2006 06:49 PM
The Civic Project
Aug 13, 2004 04:57 PM
