d16y5 onto y7 mini me EGR question.
Old Apr 23, 2008 | 08:49 PM
mini-e's Avatar
Default d16y5 onto y7 mini me EGR question.
it's pretty much together but the harness (marked 96 hx 5 speed by the junk yard) has a 5 blade connector for the EGR valve and the EGR valve (off a 2000 hx) has a 3 blade connector. The Hanynes manual shows 5 wires and everything i have seen regarding 96-00 HX shows 5 wires. Is there a 3 wire EGR that would fit and it was swapped from a CRX or something or did Honda switch to a 3 wire EGR in 2000 on the HX? Everything takes longer that you think it is going to. Any ideas on how to wire it?
Another Odd thing is the harness did not have knock sensor wire at the connector or in the loom. I had to add it. Did some HXs' come without knock sensors?
Thanks.
Xellvar
14
May 17, 2017 04:32 PM
orangeracer
Aug 12, 2007 10:21 AM
SilverGT
14
Mar 30, 2007 01:54 PM
Del
Dec 31, 2003 10:20 AM
