Turn signal help for 03 EP.
Old Apr 23, 2008 | 08:23 PM
Ghuy's Avatar
Default Turn signal help for 03 EP.
This started happening to me a day ago. Whenever I use the turn signals while I'm pressing the brakes, they dont work. Even the hazards dont work. I thought it was a fluke at first but everytime I have the turn signals on and then press the brakes, they shut off. Is it a fuse or wiring problem?
Old Apr 24, 2008 | 03:03 AM
WyldRice's Avatar
Default Re: Turn signal help for 03 EP. (Ghuy)
i would
1. check the bulbs- make sure they are not flickering or weak (mine had this problem!)
2. then i would take the fuses- and swap with other fuses in the box (since we know they work!)
3. check for repainting around bulbs- (ground wires not making contact)
4. last is the wiring, which is a pain in the u know what!
a. keep the lights on, and wiggle the wiring line... any luck?
b. if nothing helps, yank it all out
c. new wires, bulbs, fuses.
Good Luck!
Old Apr 24, 2008 | 07:46 AM
canadianep3's Avatar
check out the hazzard lights if the plug on the back of the hazzard button isnt hooked up ur turn lights dont work maybe its loose or something
Ek Steve
13
Jan 14, 2020 07:10 PM
nitro911
Sep 7, 2011 02:38 AM
andyisftw
May 14, 2010 10:55 AM
ty_uni_ek08
Sep 10, 2008 07:26 PM
eg8000rpm
Apr 27, 2005 12:37 PM
