B Series Swap?
Old Apr 23, 2008 | 06:38 PM
Jizzo's Avatar
Default B Series Swap?
Can anyone help me do a complete B-series Swap in an EK? Its been already swapped with B16 but were tryin to take it out and put in a B18 instead..
Old Apr 23, 2008 | 07:06 PM
b16a3delsol's Avatar
Default Re: B Series Swap? (Jizzo)
simple motor swap undo the harness and axles. take the mounts loose and pulle the thing out.
Old Apr 23, 2008 | 07:34 PM
Jizzo's Avatar
Default Re: B Series Swap? (b16a3delsol)
I have done the swap before.. Into me old EG.. But that was like 5 years ago.. And a friend of mine just told me what to do.. But that was so long ago..
Old Apr 23, 2008 | 08:06 PM
lilo_goki's Avatar
it's easy man, u'll save money too. just unplug ur harness from the shock tower plugs, take the fuel line that connects to fuel filter off, take off axles, disconnect negativer battery and postive battery that goes to starter, disconnect all mounts and ur header where it connects to ur cat and u should be good to go. just get a cherry picker and lift the torque less b16 out and put in the 1.8 liter monster. unless u wanna spend money on it, then go for it. if u were close by, i'll do it for $300. i've done 5 motor swaps already and everything was good and it looks clean as well.
Old Apr 25, 2008 | 09:21 AM
Jizzo's Avatar
Default Re: (lilo_goki)
Thanks for the all the info!! Hopefully I will be able to do it again!! Without anyones help..
Old Apr 25, 2008 | 10:48 AM
ek4_b16a's Avatar
Default Re: (Jizzo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilo_goki &raquo;</TD></TR><TR><TD CLASS="quote">it's easy man, u'll save money too. just unplug ur harness from the shock tower plugs, take the fuel line that connects to fuel filter off, take off axles, disconnect negativer battery and postive battery that goes to starter, disconnect all mounts and ur header where it connects to ur cat and u should be good to go. just get a cherry picker and lift the torque less b16 out and put in the 1.8 liter monster. unless u wanna spend money on it, then go for it. if u were close by, i'll do it for $300. i've done 5 motor swaps already and everything was good and it looks clean as well.</TD></TR></TABLE>
just wanna point out that the 96-00 civics didn't come with the two piece harness...they are one piece...so you will either pull out your entire engine harness or just unclip all the clips from the motor...gl only will take a few hours if you're doing it by yourself...gl again!
Old Apr 25, 2008 | 10:53 AM
eg6imola's Avatar
what are you down with the b16?
wanna sell?
CTR-GSR
10
Jul 8, 2006 06:45 AM
illicon2003
Feb 6, 2004 07:32 PM
