just a couple quick questions.
i have an 88 crx si with a b16a1 in it. i need new shifter bushings because there is alot of slop in the shifter. i've seen the diy write-ups but i need to know what to buy. would i but the bushings made for the CRX or bushings to match up with the engine / trans?
next question. through my research i have found that the rear suspension set up is diff in the 88 as opposed to the 89-91. i have a friend that has a rear disk set up from a DA integra, will that work with aftermarket coilovers made for the 89-91? also are there any good coilover set-ups that will fit the 88 without modification?
please don't tell me to search. i searched already.
thanks in advance for your help.
As far as the shifter bushing password:JDM makes a good bushing for the shifters.
When you do the rear disc conversion people usually use the DA LCA's for the sway bar mounts, Im about 100% sure that you can use the same coilovers for all the CRX's.
for the shifter bushing you would need the one from an 90-up integra. as for the rear disk brakes, the 89-91 suspension set would work if you use the da lca. the 88 is the itr eyehole lca.
hillbillycivic
Mar 13, 2013 08:14 PM
RCautoworks
Dec 4, 2002 04:18 PM
