I need help with my 89 Si.. its running really bad... HELP
Old Jul 12, 2002 | 10:29 AM
crxtreme27's Avatar
Default I need help with my 89 Si.. its running really bad... HELP
Last sunday i was driving and i almost ran out of gas completely... so i went to Shell (I wanted chevron or 76 but i didnt think i would get there with the gas i had..) and filled up.... then right after i filled up i was on my way home... i noticed that the car was hesitating when i stepped on the gas.. so i pulled over and turned off the car... then when i started it up again it was running like ****... it was boggin and then the muffler started to pop really loud when i was accelerating, it backfires really bad... i already checked the timing and the distributor but still runs the same.. what can i do??
thanks
Old Jul 12, 2002 | 10:33 AM
technine's Avatar
Default Re: I need help with my 89 Si.. its running really bad... HELP (crxtreme27)
replace plug wires, plugs, maybe you got a bad tank of gas, I don't know, but check those too. Happend to me and that was kinda the last thing on my mind, but that was the problem.
Old Jul 12, 2002 | 11:33 AM
gregv's Avatar
Default Re: I need help with my 89 Si.. its running really bad... HELP (technine)
sounds like a bad tank of gas, or you sucked in some crud from the bottom of your tank into your fuel filter and/or injectors.
good luck
Old Jul 12, 2002 | 01:55 PM
tunedcivic's Avatar
Default Re: I need help with my 89 Si.. its running really bad... HELP (gregv)
spray some injector cleaner in ur tank and run that through maybe it will clkean up the **** u probably ran in when u ran dry.
Old Jul 13, 2002 | 10:45 AM
crxtreme27's Avatar
yeah... i think ill get some injector cleaner and if that doesnt solve i guess ill be draining the tank...
thanks
juba_x
Aug 12, 2010 07:36 AM
KraziCivicSi
Jun 30, 2008 05:27 AM
r1ch1e
May 24, 2007 11:34 AM
ActiveAero
Jul 3, 2003 11:27 AM
