diff. y8 intake manifolds
Old Apr 23, 2008 | 04:25 PM
jxn0051's Avatar
Default diff. y8 intake manifolds
long time lurker first time poster.
- Im finally doing my intake manifold swap (99-00 manifold into 92 z6)and I just realized that the gasket sets are different between the 4 door and 2 door intake manifolds, this also includes the throttle body gaskets
- I apparantly received a manifold from a 4 door and my new gaskets will not fit.
My question is if this will still fit on the z6 as some of the holes no longer line up properly on the gasket, any leaks? Anybody ever run into this problem before?
- check out majestic honda and you will see the diff. gasket sets(btwn 99-00 model 2 dr 4dr ex).
I can certainly send some photos if you like of the gskets not fitting properly.
- unfortunately the car is in paint, so i have no access to check myself
- also did a search and no luck.
AllmotorGSReg
20
Apr 12, 2013 05:57 PM
stripery2bk
Jan 19, 2006 09:20 PM
young noob
Sep 16, 2005 10:44 AM
ftwlucky13
Mar 21, 2005 02:43 PM
