What Springs a Struts?
Anybody know what struts and springs will convert too a 2000 CR-V? I would like to lower it 2 inches all the way around. I have looked all over this sight before posting nothing for a CR-V as far as where to get it, Seen what most people have used Koni shocks, different type of springs but are you using ones for a different Honda/Integra? Thanks for help and knowledge
Modified by NoobCR-V at 7:27 PM 4/23/2008
Fitting PI Lowering springs to your vehicle is the most economical way of making your car feel and look good making the handling more responsive along with greater road holding over the standard factory fitted springs.
I recommend you fit PI bump stops to the damper shaft as it helps prevent impact damage on the dampers .
We recommend the fitting of suspension kits be carried out by a competent technician using suitable equipment.
______________________________________
Side Marker Accessories | Radiator Hose Parts
