90+ flywheel and 88 tranny, what clutch combo?
Old Apr 23, 2008 | 01:18 PM
Tyson's Avatar
Default 90+ flywheel and 88 tranny, what clutch combo?
so i'm swapping in my spare engine in my 88. i want to use a 90+ flywheel, but my 88 tranny is still good for the street.
i remember there is a combination i can use to match the splines of the 88, and diameter of the 90+ flywheels.
anyone know?
or should i just use the complete 88 kit on the bigger flywheel?
Old Apr 23, 2008 | 02:16 PM
SIred91's Avatar
Rainman
Default Re: 90+ flywheel and 88 tranny, what clutch combo? (Tyson)
Always use the clutch that matches the transmission.
The release bearing/pressure plate/disk anyway...flywheel has options
Old Apr 23, 2008 | 02:27 PM
90crxdriver's Avatar
found a great site to see all the dimetions on the clutch parts on all/most of the honda cars.
http://www.clutchcityonline.com/standard.htm
What you need is a
8 3/8" disc. diam.
7/8" spline diam.
21 spline
The 86-89 honda accord 2.0L clutch disks are
8 1/4" disc diam.
7/8" spline diam.
21 spline
1/8" smaller plus its $42.86
Old Apr 23, 2008 | 02:35 PM
Tyson's Avatar
Default Re: 90+ flywheel and 88 tranny, what clutch combo? (90crxdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdriver &raquo;</TD></TR><TR><TD CLASS="quote">found a great site to see all the dimetions on the clutch parts on all/most of the honda cars.
What you need is a
8 3/8" disc. diam.
7/8" spline diam.
21 spline
8 1/4" disc diam.
7/8" spline diam.
21 spline
1/8" smaller plus its $42.86</TD></TR></TABLE>
thats the info im looking for.
which pressure plate? 90+?
Old Apr 23, 2008 | 02:42 PM
welfarepc's Avatar
88 clutch disc info
200MM X 21 SPLINE
ACURA INTEGRA
ACCORD 79-85
CIVIC 1988
PRELUDE 79-87
88-89 Accord clutch disc info
212MM X 21 SPLINE
ACCORD 86-89
PRELUDE 85-87
so i would say use a 90+ 210mm clutch cover (or 92-95 vtec, which is 212mm... yet 90-95 all use the same flywheel...) let us know!
Modified by welfarepc at 3:50 PM 4/23/2008
Old Apr 23, 2008 | 04:21 PM
I'm running a 88 trans with my 90 lightweight flywheel.
I used the 90 flywheel, 90 pressure plate and a 86-89 clutch disk.
Old Apr 23, 2008 | 04:24 PM
Tyson's Avatar
thanks guys (90crxdriver, welfarepc)
Old Apr 24, 2008 | 10:01 AM
Tyson's Avatar
well i made an order yesterday with GRIPFORCE, the rep i was talking to said it wouldnt work so i just bought the standard 88 kit anyway.
but then i got more information from you guys and saw that clutchcityonline has a specific kit including the 90 flywheel to fit a 88 tranny. i asked if they can give me that kit without a new flywheel and they said no problem. so i cancelled my order with gripforce. theyre charging me 10% cancellation on a $100 order, so whatever. beer money i guess...
at least CCO knows whats up. i recommend anyone going straight to ClutchCityOnline if youre interested in this setup.
odd tho, they dont list the accord flywheel as what they provide in the kit. it actually matches the 8 3/8 full diameter of the 90 flywheel. the accord is listed as 8 1/4, 1/8 short. so it looks like they found a better alternative.
when i get the kit, i'll let you guys know for sure.
Old Apr 24, 2008 | 09:31 PM
mario_pic's Avatar
u want somthing crazy grabby that works nice for a stock clutch do what i did get a stock exedy clutch and press plate for a 96 civic and go to a scrap yeard and get a 96 civic flywheel if u got a 90 91 tranny it will fit and work amazing i had it runing for a year it grabed as good as a stage 3 lol my buddys where dieing when thay found out what i came out with lol it slams good and sticks nice hard thing is for stop and go driveing takes some getting use to to keep it from jumping lol
Old May 3, 2008 | 11:21 PM
Tyson's Avatar
Default Re: 90+ flywheel and 88 tranny, what clutch combo? (mario_pic)
so i put the clutch in today. along with swapping a new engine. with so much else to worry about, im glad there was no drama with the clutch fitment.
i was hugely pleased that the disc was actually 212mm. so it was NOT from an accord. its perfect, 21 splined and fit a 1990 pressure plate and used my 16 lb SOHC ZC flywheel.
clutch city online definately pulled thru. im so glad i cancelled my order with gripforce. their customer service was definately lacking in comparison.
DA91TEGGY
Jul 22, 2005 01:19 PM
nuc79
Feb 1, 2004 08:21 PM
PaImportTuner
11
Jan 16, 2004 09:49 AM
memphiss13
Feb 7, 2003 02:33 PM
CimorelliCRX
16
Dec 12, 2002 05:13 AM
