holy shit! alignment cost?!
Old Jul 12, 2002 | 09:56 AM
djay86's Avatar
Default holy ****! alignment cost?!
I went to make an appointment today.. the guy said the alignment would be over 80 dollars depending on what they would find.. He said the reason for this was because it was lowered.
What can I do about this, or is there nothing i can do besides coughing up the cash?
Thanks.
Old Jul 12, 2002 | 09:59 AM
Blaze45's Avatar
Brrraaaap!
Default Re: holy ****! alignment cost?! (djay86)
Comes w/ the lowering territory. Where are you having it done @? Mines gonna cost like 45(thrust alignment) at Les Schwab. They had the cheapest price. Although mine isnt lower'd.
Good luck
Blaze
Old Jul 12, 2002 | 10:40 AM
technine's Avatar
Just go to another place and shop around or take it up the... and you like it
Old Jul 12, 2002 | 11:51 AM
d357r0y's Avatar
Default Re: holy ****! alignment cost?! (technine)
go to Sears. they are like $50 and will readjust it with int 6 months or 6K miles (whichever comes first)
Old Jul 12, 2002 | 12:19 PM
NikoZai's Avatar
Default Re: holy ****! alignment cost?! (d357r0y)
With slamming your car there are things to consider.
1. wheel well clearance.
2. Alignment.
3. Camber adjustment (probably need a camber kit)
4. Axles breaking/CV joints/boots blowing out often.
Too many people lower their cars to the extreme without knowing what they're effecting (damaging) by doing so.
edit: and $60 is the max i'd ever pay for just alignment.
but factor in 25-40 for a camber adjustment (if you have the kit) (kit is $200)
if they'll do that too.
[Modified by NikoZai, 9:21 PM 7/12/2002]
Old Jul 12, 2002 | 01:32 PM
johnzm's Avatar
Default Re: holy ****! alignment cost?! (NikoZai)
i usede to do alignments at firestone. and a 4 wheel alignment is all thats needed on a civic/crx. u guys who are getting charged extra becasue of stupid **** like that. its not right. a 4 wheel alignment pays 1.2 hours for the job. thats a LOT of time, and its more than enough to facotr in camber kit changes. in fact, they did not allot me extra time if i had to shim a car, and it usually still took less than 1.2 on those... go someplace else.
Old Jul 12, 2002 | 03:00 PM
Steve91's Avatar
Default Re: holy ****! alignment cost?! (johnzm)
What does this magician plan to "align" on your car for $80? The only factory adjustments are to front and rear toe. Camber and caster are not factory adjustable.
Do you have some aftermarket camber stuff? If so, then I can see him earning his $80.
Old Jul 12, 2002 | 05:36 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: holy ****! alignment cost?! (Steve91)
$30 sounds more resonable.
Old Jul 12, 2002 | 09:29 PM
Home Skillet's Avatar
Default Re: holy ****! alignment cost?! (SpoonSportsEF7)
WOW $30!! where is this?
Old Jul 12, 2002 | 11:38 PM
Quik89Si's Avatar
Default Re: holy ****! alignment cost?! (Home Skillet)
I work at Sears, the dude who works in auto hooked me up good...I needed two tires installed and balanced, as well as stems, and a 4wheel alignment after I put on Neuspeed sports and Bilsteins...
He only charged me $45 for all that.
Oh and by the way...I just installed a new Sparco steering wheel, and it wouldn't line up straight when I put it on. It sits slightly turned to the left when I'm driving straight. Do they fix this with alignment?
Thanks -
Alex
jdmstreethatch
Suspension & Brakes
Feb 4, 2006 11:52 AM
LAOS
Suspension & Brakes
18
Sep 17, 2005 12:48 PM
turbotime
May 14, 2005 12:39 PM
2001civ
Dec 29, 2002 03:28 PM
eTec
Apr 17, 2002 08:22 PM
