99ek b16 swap
hey guys my friend who i trust has a rebuilt b16 bottom end with upgraged pistons and rods and the block is sleeved it has next to no miles since it was rebuilt. and he has a gsr head with type r cams on it and a gsr tranny.. he wants $2000 for it.. he saying its makin like 220 hp i believe the block is obd2
so my question is does this sound like a good deal?
also what would i have to do to get this in my 1999 honda civic ex? please help me out with all aspects including wiring for obd2 and obd1 thanks guys
If you trust him as a engine builder than yes, that is a great deal.
As far as putting it in your car, if the motor is obd2 then everything will be easy. Just about everything will wire up except for dizzy & IAT, both are simple fixs cut and splice the correct plugs in, other than that you can utilize all your mounts except for the rear T mount which you will need to order. Slap on some axles and shift linkage and call it a day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blade0314 »</TD></TR><TR><TD CLASS="quote">hey guys my friend who i trust has a rebuilt b16 bottom end with upgraged pistons and rods and the block is sleeved it has next to no miles since it was rebuilt. and he has a gsr head with type r cams on it and a gsr tranny.. he wants $2000 for it.. he saying its makin like 220 hp i believe the block is obd2
also what would i have to do to get this in my 1999 honda civic ex? please help me out with all aspects including wiring for obd2 and obd1 thanks guys</TD></TR></TABLE>
The day i see a B16 block pump out 220 NA hp to the wheels using honda OEM components will be the day I punch my boss in the face.
at best its making 160 to the wheels, and even that would be VERY surprising.
Whats the Compression ratio on the motor with the new pistons and rods?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc »</TD></TR><TR><TD CLASS="quote">
Whats the Compression ratio on the motor with the new pistons and rods?</TD></TR></TABLE>
Agreed. Sounds like a solid motor, but thats not really a realistic number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blade0314 »</TD></TR><TR><TD CLASS="quote">otta ask him about it more but i kno its not stock oem pistons and rods </TD></TR></TABLE>
OEM head though is what I mean, no mention of it being ported, or aftermarket valve train.
Aftermarket pistons/rods will be stronger, but typically are meant to raise, or lower compression. high compression = marginally higher NA HP across the power band *not 30-40hp higher, thats for damn sure*, Low compression = lower NA HP, but easier/safer to tune for boosting.
No offense to your friend, but if he told you 220hp he is already full of **** regardless of what kinda pistons are in it.
the only motors I've seen break 200hp NA are built ITR motors, a few fully built LS/Vtecs, and K motors.
the only motors I've seen break 200hp NA are built ITR motors, a few fully built LS/Vtecs, and K motors.</TD></TR></TABLE>
Once again +1
Once again +1
civic702
Sep 8, 2005 09:58 PM
