High beams work low beams do not
Old Apr 23, 2008 | 07:11 AM
eghatchin's Avatar
Default High beams work low beams do not
so when i have my high beams on they work just fine but if i switch to low beams my lights altogether turn off. but sometimes the low beams will stay on for a little bit and slowly get dimmer and dimmer untill it turns off
Old Apr 23, 2008 | 11:41 AM
mechanix619's Avatar
Default Re: High beams work low beams do not (eghatchin)
Bad wire and/or bad bulb.
Old Apr 24, 2008 | 06:31 AM
eghatchin's Avatar
replaced bulbs and does the same thing
Old Apr 24, 2008 | 06:33 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: (eghatchin)
Check the wires that run to the bulbs.
Also check the wiring on the headlight switch itself.
Old Apr 24, 2008 | 06:41 AM
tha_badguy's Avatar
check ur fuses...
Old Apr 24, 2008 | 10:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghatchin &raquo;</TD></TR><TR><TD CLASS="quote">replaced bulbs and does the same thing</TD></TR></TABLE>
Then it's a bad wire, or connection.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">check ur fuses...
If it was a bad fuse the bulbs wouldn't work at all.
Old Apr 24, 2008 | 06:56 PM
eghatchin's Avatar
it wouldnt be a fuse because they work for a couple of seconds sometimes
Old Apr 24, 2008 | 06:57 PM
eghatchin's Avatar
could it possibly be the plug going to the bulbs
Old Apr 24, 2008 | 08:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghatchin &raquo;</TD></TR><TR><TD CLASS="quote">could it possibly be the plug going to the bulbs</TD></TR></TABLE>
It could be the plug which would mean it's the wiring like I said earlier, however, it is odd that the wiring is messed up on both sides.
Old Apr 24, 2008 | 09:00 PM
It looks like I may stand corrected. I looked at a fuse diagram, it looks like there are fuses for both high and low beam. Can you please verify this and check to see if your low beam fuses are blown? They should be 10A fuses.
Old Apr 25, 2008 | 06:48 AM
eghatchin's Avatar
have checked and they were not, but if the fuses were blown why would they work for a little bit once and a while
Old Apr 25, 2008 | 12:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghatchin &raquo;</TD></TR><TR><TD CLASS="quote">have checked and they were not, but if the fuses were blown why would they work for a little bit once and a while </TD></TR></TABLE>
Sometimes fuses don't completely blow, they crack a little allowing the component to work.
Old Apr 25, 2008 | 12:47 PM
tha_badguy's Avatar
Default Re: (mechanix619)
i hate to quote myself but...
Old Apr 25, 2008 | 03:44 PM
B MaN Si's Avatar
wires
Old Apr 25, 2008 | 04:04 PM
Former User's Avatar
You may have a bad combination switch on the steering column.
Old Apr 25, 2008 | 04:22 PM
Nichelson_Performance's Avatar
Default Re: High beams work low beams do not (RonJ@HT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT &raquo;</TD></TR><TR><TD CLASS="quote">You may have a bad combination switch on the steering column.</TD></TR></TABLE>
yea or a wiring problem
Old Apr 25, 2008 | 04:46 PM
SiYouLater's Avatar
What kind of bulbs are you running?
civicx
Dec 13, 2016 05:32 AM
Dub C
May 28, 2011 01:25 PM
PreludeGirl123456
Oct 5, 2007 09:25 PM
drptgsr
Jan 10, 2005 09:25 PM
Civic4doors
11
Feb 12, 2004 01:39 AM
