what is a dizzy and what does it do and what causes black smoke?
just wondering what a dizzy is because i dont know but, what can make a car smoke black out the exhaust if you could help me out that would be the s#@*
holy [freak]ing ****
ok dizzy is the god dam distributor
black smoke equals the engine is running rich... im going to have to assume you dont know what that means... so running rich is the motor is getting to much fuel and the air to fuel ratio is to rich. you are loosing power because of this.
dam use the seach function noob!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiero87 »</TD></TR><TR><TD CLASS="quote">holy [freak]ing ****
i really lmao! nice.
Black smoke means you car is too damn fast
and a dizzy is a distributor in which creates the spark that fires the plugs that ignites your fuel that pressurizes your cylinders that push your pistons to rotate your crank to power your wheels so you can go vroom
haha jk
too much fuel, running rich, due to a bad 02, fuel pressure off, timing off Or many other reasons ( check for CHeck engine light codes)
haha jk
thanx who the [freak] cam up with that stupid *** **** dizzy thats retarded and it was vacume lines that were the cause off black smoke thanx guys
