multiground question
Old Apr 22, 2008 | 11:39 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default multiground question
The multi-grounds by the head lights for the wiring harness.
Do i need to use these or can i remove them and ground the wires in other areas?
or could i just connect all the grounds to one ground and it all work the same?
Old Apr 23, 2008 | 05:10 PM
crxzcracer's Avatar
Default Re: multiground question (crxzcracer)
Bump
Old Apr 23, 2008 | 10:28 PM
crxzcracer's Avatar
okay let me explane more..
what i want to do is take the ground wires that run from the inside of the car and ground them inside the car and take all the grounds from the headlights,radiator fan relay,and turnsignals, and windsheild whiper motor and ground them closer to where they are mounted instead of useing the multi-ground.
can i do this or will it cause problems?
Modified by crxzcracer at 2:14 AM 4/24/2008
Old Apr 24, 2008 | 12:02 PM
Perfectionist's Avatar
IF your contact points are clean, solid, and are mechanically connected by decent steel or adequate gauge wire to your main ground point(s), I don't see why it should cause you any problems.
Old Apr 24, 2008 | 07:05 PM
crxzcracer's Avatar
Default Re: multiground question (Perfectionist)
Yeah i figured so but i just wanted to see if there was any thing special about the way it was wired up.
thanks
Old Apr 24, 2008 | 07:07 PM
zrickety's Avatar
as long as the battery is grounded to the frame properly, you can ground them anywhere, including the battery. i've added extra, thicker ground wires to my past few cars with only positive results. no pun intended
stevenr2894
10
Mar 9, 2013 10:23 AM
willskillz805
10
Aug 17, 2009 09:08 PM
Downtown
Audio / Security / Video
Aug 8, 2007 11:35 AM
Liquidgsr
12
Mar 18, 2005 07:48 PM
Whitegsr2000
Jun 1, 2003 07:28 PM
