93 Hatch No Start.
Old Apr 22, 2008 | 09:14 PM
dividedas1's Avatar
Default 93 Hatch No Start.
So i have a 93 hatch swapped with a b16a. I stalled the car tonight at a light, it wasnt a rough stall but it still died, when i first tried to re-start the car all it would do is crank. So i stopped and tried again and it fired up and i made it home.
Now that its home it doesnt want to start at all. what i have noticed is that when i go to turn the key in the ignition nothing happens. For example all the lights that flash on your dash before the car starts, the heat/ac panel lights up briefly then dims out. So basically im assuming im not getting fuel or spark on it. Does anyone have any ideas what could be wrong here? kinda sucks cause i got this car less then a month ago.
Old Apr 22, 2008 | 09:45 PM
dividedas1's Avatar
Default Re: 93 Hatch No Start. (dividedas1)
bump b4 bed. please help me
Old Apr 22, 2008 | 10:49 PM
JD126X's Avatar
If the lights dim out, looks like you might need to jump start it (battery might not be fully charged). Try that first and make sure you have a fully charged battery. After your sure you have a fully charged battery and it doesn't start check your fuses.
Old Apr 23, 2008 | 04:00 AM
dividedas1's Avatar
Default Re: 93 Hatch No Start. (JD126X)
its not the lights or radio that dim out... it the ac/heater buttons, ya know how they light up usually lol well when i turn the key they light up then dim out like theres something wrong.. idfk i guess im going to go start pulling fuses.
someone on here has had to of had this happen b4
Old Apr 23, 2008 | 04:35 AM
dividedas1's Avatar
so checked all the fuses and nada. everything is all good there. I know its not the battery because like i said my radio works. its just when i put the key in the second on position nothing happends... my cluster doesnt light up, my ac/heat doesnt turn on. could this possibly be an ignition switch problem?
Old Apr 23, 2008 | 05:29 AM
blkegcoupe's Avatar
From: ....................................................................................................
does the cel turn on also? then turn off? might not be getting primed
Old Apr 23, 2008 | 06:03 AM
dividedas1's Avatar
Default Re: (blkegcoupe)
lol like i said nothing happens when i put the key in the on position. no dash lights no priming nothing.
Old Apr 23, 2008 | 12:51 PM
Ransom's Avatar
Default Re: (dividedas1)
Check your ignition switch.
Old Apr 23, 2008 | 01:27 PM
slvrcvc93's Avatar
Default Re: (LudeSH)
The Ignition switch or Main Fuse under the Hood will have same affect try to put a different battery anyway to make sure because if you have no lights turning on its a an electrical component. Even with a bad ecu the dash lights still all turn on
Old Apr 24, 2008 | 05:07 AM
dividedas1's Avatar
Default Re: (slvrcvc93)
it was the 50 watt fuse under the hood...the big guy fried and some stupid other electrical issues.. thanks everyone for the idears
rugimpy
Aug 23, 2010 11:56 AM
Eg Fool
19
Sep 12, 2009 07:28 PM
itslogz
May 1, 2009 07:10 AM
ekVtecPower
37
Jun 2, 2006 10:01 PM
halocivic
Honda Civic (2001 - 2005)
May 6, 2006 08:27 AM
