JDM cluster brigher/brightness adjustments
Old Apr 22, 2008 | 09:14 PM
Rikaro's Avatar
Default JDM cluster brigher/brightness adjustments
i'm sure you all know when you use the JDM (i have the SIRII) clusters the brightness is at the lowest and can not be adjusted. Is there anyone who know how to make them brightest, or make it so that the brightness scroll would work on the cluster as well?
I tried replacing them LED and they're still weak. I guess it's the power outage that is affecting brightness.
Old Apr 22, 2008 | 11:07 PM
-JAWSHUA-'s Avatar
they are the same my CTR cluster is bright as can be and adjusts perfect.
Old Apr 22, 2008 | 11:38 PM
Rikaro's Avatar
Default Re: (-JAWSHUA-)
so i'm guessing it's only the 92-95 SiR clusters. My friend has the same cluster and it does the same thing
generation_D
Aug 16, 2009 08:36 AM
