Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Rotary air control valve problem?
Old Apr 22, 2008 | 08:04 PM
kailapics's Avatar
Default Rotary air control valve problem?
My 2001 civic (147,000 miles) tends to idle low when I stop in local traffic. This only happens during the spring/summer weather when it is warm (no problems in the winter). If I stall, my car starts right up. I don't use the a/c since it doesn't work that well anyway. I have taken it to mechanics but I am told it is not a big deal. I don't know much about cars, but I have read some and some have suggested that the rotary air control valve (I am not sure what that is) may need to be replaced or cleaned. The problem is inconsistent - but seems to be prevalent on warm days. Any idea of what is going on before I pour money into it - and take it to another mechanic? Much thanks.
Old Apr 22, 2008 | 08:14 PM
Boilermaker1's Avatar
Idle air control valve?
Its the port in the side of the throttle. Take it off the IM and get some throttle body cleaner.
Old Apr 22, 2008 | 08:42 PM
Jellotree's Avatar
Default Re: Rotary air control valve problem? (kailapics)
I just did this with my car. Pick up a can of throttle body cleaner (spray can). Follow the directions. When you take your air filter off and look into the air intake, you'll see a small port. That leads to your RACV. Make sure you get the spray tube in there and give it a good spray.
Oh, and you've got the name right (rotary air control valve). As I was researching it, apparently that's what Honda calls their IAC.
Old Apr 23, 2008 | 10:36 AM
kailapics's Avatar
Default Re: Rotary air control valve problem? (Jellotree)
Thank you both so much. I think I will try to get someone to do this for me as I am very inexperienced with working on cars
Old Apr 23, 2008 | 01:22 PM
LatinEM2's Avatar
if you know where it is heres a pic:
Old Jul 16, 2009 | 11:34 AM
rgs258's Avatar
Hi, just wondering if this (cleaning) fixed your problem?
Thanks.
Old Jul 16, 2009 | 11:58 AM
toyomatt84's Avatar
Sanji
Thanks.
Just as a head's up, it's been over a year since the last response to this thread. I wouldn't get my hopes up for a response.
Old Jul 16, 2009 | 12:10 PM
Rob.C's Avatar
At least he did a search.
Old Jul 16, 2009 | 12:24 PM
toyomatt84's Avatar
Sanji
Hence why I just didn't delete his post.
Old Jan 29, 2013 | 07:55 PM
tprietojr's Avatar
Default Re: honda idle problem
i have a honda civic 2004 model im having idle problem when on stop idle go up and down .and engine dies automatically rpm drop i already clean the idle control valve w/ the carburator cleaner but the same thing happen to the car by the way is idle control valve same as rotary air control valve if it not the same thing where is the location of the rotary air control vave in the engine
Old Jan 30, 2013 | 04:27 PM
toyomatt84's Avatar
Sanji
Your car does not have a Rotary Air Control Valve... only an Idle Air Control Valve.
Old Feb 4, 2013 | 01:43 AM
tprietojr's Avatar
ok ive clean remove the idle control valve from my car use the whole can of clean. after start the car and use it it was ok at first few day but the problem is still there it was not fix. any more ideas what wrong in the car
Old Feb 4, 2013 | 01:46 AM
tprietojr's Avatar
Joe Techy
Honda CR-V & Element
Feb 16, 2019 07:35 AM
Kodi Dubea
Apr 19, 2018 03:43 PM
crxsir23
Feb 10, 2008 04:25 AM
'00GSR
Aug 30, 2006 08:58 PM
