Bumper Removal
Old Apr 22, 2008 | 05:34 PM
96_Accord_lx's Avatar
Default Bumper Removal
I have no idea how to remove my front bumper at all... Its a 96 accord lx 4dr. Any one got pics on how to do it? Thanks alot. Also my front fenders and headlights are off center and not lining up right so how do i fix that?
Old Apr 22, 2008 | 07:36 PM
93accordxl's Avatar
Default Re: Bumper Removal (96_Accord_lx)
Two bolts inside the engine bay probably,
Then theres supports where the bumper lights are, then there may be some more where the bumper lines up to fender.
Old Apr 22, 2008 | 07:39 PM
AP96's Avatar
one screw on the inside each fender remove that, remove bumper lights; that reveals two bolts take those off and pull up and out and your bumper is off.
Oh I take it you didn't search either?
Old Apr 22, 2008 | 07:50 PM
TheMuffinMan's Avatar
He knows where you live!
It's actually:
2 10mm bolts bottom of fender liner/bumper (where it wraps under)
2 phillips head screws at the top of the bumper where it meets the fender
2 12mm or 14mm on either side behind the turn signals (remove the signals with a single phillips from the lower grille)
I found removing the corners and grille helps but isn't totally necessary
Old Apr 22, 2008 | 07:58 PM
AP96's Avatar
Eh I contributed, I also noticed you're from Jenks. Really close to where I live.
Old Apr 22, 2008 | 08:09 PM
Default Re: (AP96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AP96 &raquo;</TD></TR><TR><TD CLASS="quote">Eh I contributed, I also noticed you're from Jenks. Really close to where I live.</TD></TR></TABLE>
He'd rip the fender lining though lol
OH ****!
And there's 2 plastic clips on the bottom of the bumper that attach to the subframe area
Old Apr 23, 2008 | 12:49 PM
AP96's Avatar
Haha I guess I rigged mine then to removing the screws in the fender, bumper lights, then the four bolts from the actual bumper.
Old Apr 23, 2008 | 02:13 PM
mavvrik's Avatar
The Muffin Man is 100% coorect. Couldn't have said it better myself lol
Old Apr 23, 2008 | 03:24 PM
Tyte-S's Avatar
Default Re: (mavvrik)
Rule #1: TheMuffinMan is always correct.
Old Apr 23, 2008 | 03:25 PM
Default Re: (Tyte-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S &raquo;</TD></TR><TR><TD CLASS="quote">Rule #1: TheMuffinMan is always correct. </TD></TR></TABLE>
Not always
I just know most of the stuff regarding Accords from experience.
As a side note I successfully chipped and socketed my first ECU
Old Apr 23, 2008 | 06:53 PM
WAY TO GO MUFFIN!!!! Ya i am in Jenks... Where are u? I looked many times to find where it is bolted on and never found it!!! EVER! so thanks alot for your help guys! Oh and another quick question... Will my air bags deploy if i take out the air bag sensor can in the front?
aeboync
Jan 7, 2006 05:24 PM
ergot
May 3, 2005 02:22 PM
stewart05
Nov 19, 2004 10:55 PM
azian21485
May 11, 2004 08:13 AM
