*TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out
Old Apr 22, 2008 | 05:03 PM
95ProjectEJ1's Avatar
Default *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out
<FONT SIZE="2">This is not a commercial post!</FONT>
Please BUMP if you view!!
<FONT COLOR="green">AIM</FONT> = ShonuffLoveBoost
<FONT COLOR="blue">EMAIL</FONT> = jaydubya04@gmail.com
<FONT COLOR="purple">CELL</FONT> = 714-351-4164 call and leave a message
<FONT COLOR="crimson">1995 Horizon Gray Ex (EJ1) 190k chassis</FONT>
I am almost finsihed with my project and I do not want to keep it. I am finishing it up and putting it up for sale. I have receipts for everything that was purchased after I bought the car. Some stuff was paid for in cash with no receipt, but it is all brand new. This car once belonged to "shorsh" and "spoka".
Testing Waters!!!!
1995 Horizon Gray EX Civic w/ 190k on the chassis
CLEAN TITLE
Minor dents here and there, but nothing big.
Engine/Trans
95 B18b (From Hmotors w/ est. 25k mileage)
AC and PS!!
NEW (all OEM unless listed) timing belt, headgasket, throttle body gasket, Hondata IM gasket, Full valve cover gasket/grommets, Type-R oil pump, water pump, oil pan gasket, cam seals, BDL bronze cam seal plug, cap/rotor, plugs/wires.
NEW CRV AC bracket
Intake manifold is USDM spec for an easy BAR ref pass
Purchased $180 in brand new nuts/bolts from Honda (with receipt and parts list)
Custom SS clutch line
Apexi WS2 exhaust with cat
98 JDM LS trans (SC4, from Hmotors w/ est. 25-30k... no grinds or popouts)
Bseries shift linkage with NEW ES shifter bushings (black)
NEW Exedy OEM replacement clutch.
Resurfaced flywheel
Suspension/Brakes
All the new parts listed above and below have less than 10 miles on them... keep that in mind.
GSR rear disc...
All NEW...
Skunk2 Pro-S coilovers
Skunk2 LCA
Skunk2 Pro Series+ Front Camber Kit
BLOX rear camber kit
Brembo blanks Front and Rear
PBR pads Front and Rear
SS brake lines Front and Rear
EARLs solo bleeder brake bleeders Front and Rear (for easy 1 person bleeding)
Ebrake cables
New brake and clutch fluid as well as ps fluid
Interior
Stock gray interior. Full interior. I have recently cleaned the seats and am in the process of cleaning the carpet as best as I can. All interior panels were taken out so I could clean EVERYTHING!
CONS!!!!
Driver side fender was damaged. This will be replaced by a black fender (will need repaint).
Hood latch is not working properly and will be fixed before I sell.
Radio is somewhat jacked. I have a full stereo system I got for xmas a year or 2 back that I didnt install (BNIB, headunit and front/rear speakers). Will throw in if I get a good offer.
I have a stock OEM front bumper and lip that I might throw in also. I know this is HT so a lot of people will lowball.
The motor has less than 30K on it with all brand new parts!!
<FONT COLOR="crimson">EJ1 Rear Seats *Gray*</FONT> <FONT COLOR="green">SOLD </FONT>2 Me...
<FONT COLOR="crimson">Custom SS Clutch Line *Clear*</FONT>
I had two of these, one for each of my cars. As I have stated before I am stripping one so one has to go. I purchased this off of "Luserkid". These are a great replacement for the stock setup. Made with EARL fittings and wrapped in clear tubing (some what CF look). Gives the engine bay a clean look. These will work with all B and D series LHD cars with hydro trans. Only looking to get what I paid since it has never been used - <FONT COLOR="green">$</FONT>65
http://i186.photobucket.com/al...4.jpg
http://i186.photobucket.com/al...5.jpg
http://i186.photobucket.com/al...2.jpg
http://i186.photobucket.com/al...3.jpg
http://i186.photobucket.com/al...1.jpg
<FONT COLOR="crimson">BDL Cam Seal Plug</FONT>
I have one cam seal plugs to sell. These were purchased for my stock B18b1 build and my 81.5mm B18b1 turbo build. I have sold both blocks as you have seen before so I have no use for them. They are for Honda/Acura Bseries motors. I have a Titanium cam seal plug - <FONT COLOR="green">$</FONT>22
http://i186.photobucket.com/al...i.jpg
<FONT COLOR="crimson">EARL's Solo Bleeder (Brake Bleeders)</FONT>
As I have said before I am parting out my EJ1 because I have another EJ1. I picked up two sets of these and I need to get rid of one. This pack is for front and rear disc brakes only with 1 bleeder for your clutch slave cylinder. EARL solo bleeders allow you to bleed your brakes yourself. Here is a write up my buddy did with pics and more info. Pics of mine are below - <FONT COLOR="green">$</FONT>45 shipped (set)
https://honda-tech.com/zerothread?id=2250656
<FONT COLOR="crimson">OBD1 LS Injectors</FONT>
These injectors came off my JDM B18b that I picked up from Hmotors. I have another set so I have no need for these - <FONT COLOR="green">Taking Offers</FONT>
<FONT COLOR="crimson">Random **** #1</FONT>
AC compressor off my B18b1 swap; I don't know if it works - <FONT COLOR="green">Free!!</FONT>
http://i186.photobucket.com/al...7.jpg
P2A PS Pump - <FONT COLOR="green">Taking Offers</FONT>
P54 PS Pump; No idea what its off of - <FONT COLOR="green">$</FONT>10
http://i186.photobucket.com/al...6.jpg
B18a1 Cams w/ Gears, should work with B18b/b1's - <FONT COLOR="green">$</FONT>20
JDM B18b IM; No injectors. It came off my motor from HMO. I think its an Auto IM, but still good for sensors/parts - <FONT COLOR="green">$</FONT>15
http://i186.photobucket.com/al...8.jpg
B18a1 IM; Bare and its clean - <FONT COLOR="green">$</FONT>5
http://i186.photobucket.com/al...9.jpg
<FONT COLOR="crimson">Random **** #2</FONT>
http://i186.photobucket.com/al...0.jpg
B18a/b1 Timing Belt Covers - These are off a few motors I picked up over the past year. No need for them - <FONT COLOR="green">$</FONT>10 ea.
<FONT COLOR="crimson">Random **** #3</FONT>
Water Pumps off B18b/b1's - <FONT COLOR="green">$</FONT>10 ea.
Oil Pumps off B18b/b1's; still in good condition - <FONT COLOR="green">$</FONT>10 ea.
<FONT COLOR="crimson">Random **** #4</FONT>
Water tubes w/ thermoswtich (2) // Windage Tray w/ pickup (2) // Breather Chamber (2) // Rear Main Seal; off of my B18b1's - <FONT COLOR="green">Taking Offers</FONT>
Old Apr 22, 2008 | 05:09 PM
r.wright's Avatar
Default Re: *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out (95ProjectEJ1)
Old Apr 22, 2008 | 05:14 PM
Default Re: *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out (Opossum Jenkins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opossum Jenkins &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Pics will be up as soon as I can get over to my buddies house and wash the car to snap some
Old Apr 22, 2008 | 05:24 PM
sloocivic's Avatar
Old Apr 22, 2008 | 05:46 PM
bluebird's Avatar
Default Re: *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out (sloocivic)
Old Apr 22, 2008 | 06:56 PM
Default Re: *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out (bluebird)
Thanks for the BUMPs guys. I will try to get pics up ASAP.
Old Apr 22, 2008 | 07:05 PM
beaneg6's Avatar
cant belive your gonna sell the coupe...
Old Apr 22, 2008 | 07:24 PM
gsle3per03's Avatar
Default Re: *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out (beaneg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">cant belive your gonna sell the coupe...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">cant belive your gonna sell the coupe...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">cant belive your gonna sell the coupe...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">cant belive your gonna sell the coupe...</TD></TR></TABLE>
Old Apr 22, 2008 | 07:28 PM
weaksoN!'s Avatar
bumpp thissss
Old Apr 22, 2008 | 07:32 PM
Default Re: *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out (weaksoN!)
Im just over it. I spent a lot of time on it just to sell it. Should be a good car for the next owner. I haven't even had a chance to drive it anywhere really. Still less than 10 miles driven. I will put more miles on it when I get it aligned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weaksoN! &raquo;</TD></TR><TR><TD CLASS="quote">bumpp thissss </TD></TR></TABLE>
Old Apr 22, 2008 | 07:33 PM
ek_Tart's Avatar
I don't like that your parting it out. I never get to see it.
Old Apr 22, 2008 | 07:53 PM
evil_ryu's Avatar
doh!!!!
Old Apr 22, 2008 | 08:17 PM
Del Sizzle's Avatar
Old Apr 22, 2008 | 08:19 PM
Dilly's Avatar
Default Re: *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out (Del Sizzle)
Old Apr 22, 2008 | 08:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_Tart &raquo;</TD></TR><TR><TD CLASS="quote">I don't like that your parting it out. I never get to see it. </TD></TR></TABLE>
The black one is the part out... the gray one is the full sale. Its still sitting at my buddies. You probably saw the car at Danny's when he had it (before the new parts/motor).
I think a few people on here have seen it since they did business with my friend.
Old Apr 22, 2008 | 08:42 PM
pho dac biet's Avatar
Hair Club President
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diLLy &raquo;</TD></TR><TR><TD CLASS="quote">
Old Apr 22, 2008 | 10:02 PM
JdMeF9SiR2's Avatar
Old Apr 22, 2008 | 10:13 PM
HaNgTiZZy's Avatar
BUMP FOR THIS DUDE
Old Apr 22, 2008 | 10:36 PM
Apathy47's Avatar
Old Apr 23, 2008 | 04:40 AM
Default Re: *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out (Apathy47)
TTT... good morning
Old Apr 23, 2008 | 05:15 AM
evil_ryu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
The black one is the part out..</TD></TR></TABLE>
got a hood and fenders???
Old Apr 23, 2008 | 08:06 AM
bpkmrtoes's Avatar
what happen to the z6!!!
Old Apr 23, 2008 | 08:44 AM
Twinklez's Avatar
New User
Default Re: *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out (bpkmrtoes)
how much for the oem bumper ??
Old Apr 23, 2008 | 09:25 AM
j3t1p's Avatar
"BUMP IT...LOUDER!"
Old Apr 23, 2008 | 09:41 AM
Default Re: *TW & FS* 95 horizon gray EJ1 w/ B18b // B18b parts // EJ1 part-out (Twinklez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twinklez &raquo;</TD></TR><TR><TD CLASS="quote">how much for the oem bumper ??</TD></TR></TABLE>
60 is what I paid for it and what I will take. Just needs paint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes &raquo;</TD></TR><TR><TD CLASS="quote">what happen to the z6!!!</TD></TR></TABLE>
Project still isn't done lol. And to think I thought I could make a March deadline.
I just got approved for my loan so I am looking for a 98 and up DC2 and DB8. Must have AC and PS. No highly modded cars please. Light and tasteful mods ok. No projects. I will make a WTB tread when I get home. May be interested in 99-00 Hatch and EJ8's. No salvage titles...
