paint on interior what to used to get it off???
like the title says i got some acrylic urethane paint on my interior and i was wondering if anyone here know what i can use to get it off without fading the vinyle. any suggestions will help.
These suggestions may work:
Paint - Oil Base - Sponge stains with turpentine, cleaning fluid or paint remover. Pre-treat and wash in hot water. For old stains, sponge with banana oil and then with non-flammable dry cleaning solvent. Wash again. Water Base - Scrape off paint with dull blade. Wash with detergent in water as hot as is safe for fabric.
To remove paint from colored material, dip the stains in turpentine, rub, then dip in a little ammonia, rub and wash in warm water.
To remove wet paint from white material wash the stain with soap and water and boil with a small amount of paraffin in the water. Dry paint on white material can easily be removed by steeping the stain in turpentine. Rub well and wash in the ordinary way.
Paint Spots - Scrape dried paint with dull blade. Sponge with several applications of equal parts ammonia and turpentine. Wash in hottest water safe for fabric.
______________________________
EBC Brake Rotors | Mud Flaps Parts
thanx for the info but i am not sure if that well work but i'll give it a try and well see what happens. (i tried using goof off worked a little but not much)
supersilverdc2
Paint and Body
Dec 21, 2015 07:57 PM
