dohc zc pistons
Old Apr 22, 2008 | 01:58 PM
rev_this's Avatar
Default dohc zc pistons
Can you swap any other stock pistons into a DOHC ZC? Or should I go after market to bump it up? If so can anyone throw me some ideas? Looking to go the all motor route and bump up compression. The motor is already out. Thanks for the help.
Modified by rev_this at 4:46 PM 4/22/2008
Old Apr 22, 2008 | 02:00 PM
dr_latino999's Avatar
Default Re: dohc zc pistons (rev_this)
Due to the volume of the combustion chambers, I don't think it is possible to raise the compression any higher on the DOHC ZC using OEM spec' pistons.
Old Apr 22, 2008 | 04:25 PM
TreWatts's Avatar
Default Re: dohc zc pistons (dr_latino999)
you could get the civic gx pistons, but i don't know what the specs are on those.
i do know that they have a higher dome than the zc pistons though.
Old Apr 22, 2008 | 04:31 PM
SIred91's Avatar
Rainman
Default Re: dohc zc pistons (TreWatts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TreWatts &raquo;</TD></TR><TR><TD CLASS="quote">you could get the civic gx pistons, but i don't know what the specs are on those.
i do know that they have a higher dome than the zc pistons though.</TD></TR></TABLE>
GX huh? do you know what you are talking about?
If you want high compression, get an A6 and throw the PM7 pistons in it.
Otherwise, unless you get custom pistons built, I think you are SOL.....
But check on http://thezcr.com
Old Apr 24, 2008 | 09:59 AM
TreWatts's Avatar
Default Re: dohc zc pistons (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
But check on http://thezcr.com</TD></TR></TABLE>
yes, the civic gx. it was sold only in a few states and ran on natural gas, which requires higher compression. google it.
Bserieskiller
Jan 8, 2020 07:24 PM
hatchinprogress
Nov 23, 2005 11:27 AM
DOHClessEF-9
Jan 28, 2005 12:01 PM
trevorclaus
Jun 26, 2004 01:40 PM
