2003 Specialized Rockhopper Comp FSR XC Full Suspension Bike
For Sale, a 27 speed 2003 Specialized RockHopper Comp
FSR XC Full Suspension Bike in size Small with Rock
Shox Revelation Dual Air or Dart 3 Fork (you decide
the fork and the price).
The price of the bike with the Revelation Fork is $800.00
or $600 with a new Dart 3 fork.
I'm 5'7" and it fits me perfectly. This bike is light.
It's definitely under 30 pounds (if I had to guess,
27-29 pounds?). It currently has a 2006 Rockshox
Revelation 130mm fork installed. This is a super
sweet fork (about 5" of very plush travel). You can
try it by riding up an actual sidewalk and feel
nothing but a plush ride. Read the reviews of the
fork and the bike on http://www.mtbr.com (4.73/5 for the bike
and 4.68/5 for the Revelation):
http://www.mtbr.com/reviews/20...shtml
Bike with Dart 3 - $600: If you want, I can remove
the Revelation fork and put on a new 100mm travel Rock
Shox Dart 3 (entry-level) fork with a handlebar
mounted PopLoc remote lockout (let's you lock the fork
for no compression with a flick of a switch). The
fork is new and comes with a manual (take off from my
wife's brand new FSR XC). Dart 3 review (3.14/5):
The 2003 model of FSR XC was still named the
Specialized RockHopper (this bike is the Comp trim),
but it is essentially the 2002 Stumpjumper FSR frame
made out of A1 aluminum. In 2004 (same bike frame),
the RockHopper name was dropped and it was known as
the FSR XC.
FRAME: FSR technology, A1 Premium Aluminum butted
frame, sealed cartridge bearings, disc only, 75-90mm
adjustable travel, repl. der. hanger, two sets of
water bottle bosses
REAR SHOCK: Fox Float R, air spring and rebound adj.,
6.0x1.25"
FORK: 2006 Revelation offers a combination of light
weight and stiffness at 130mm that is superior to all
other standard dropout forks on the market today.
Key Features:
-All New chassis design optimized for 130mm travel
-Ultra stiff 32mm straight wall aluminum upper tubes
-Forged 6061 T6 aluminum crown
-Butted aluminum steerer
-Long Travel Dual Air spirng (+ / - air adjust)
-Motion Control Damping with adjustable Floodgate
(let's the fork compress during big hits when locked
out)
-Manual lockout
-Aluminum control *****
-Fork Weight 3.75 pounds
2nd Fork Option: Knock $200 off the $800 and get this
bike with a 100mm travel Rock Shox Dart 3 with
handlebar remote poplock lockout. Fork Weight: 4.8
pounds
HEADSET: 1 1/8" threadless (freshly cleaned and packed
with Park lubricant)
STEM: Jamis Aluminum Threadless, 1 1/8", 25.4mm bar,
120mm Extension, 10 degrees rise
HANDLEBARS: Profile Ultra FR Riser, 40mm, 610mm,
25.4mm
GRIPS: New Velo Dual Compound Flame Grips
FRONT BRAKE: Hayes Mechanical Disc MX2, 6" rotor
REAR BRAKE: Hayes Mechanical Disc MX2, 6" rotor
FRONT DERAILLEUR: Shimano M-510 Deore, 34.9mm clamp,
top pull
REAR DERAILLEUR: Shimano Deore (low mileage), Top
Normal (NOT Rapid Rise)
SHIFT LEVERS: Shimano M-510 Deore, Front/Left shifter
indicator not working (see pictue), but shifting is
buttery smooth on the front and back. Fresh cables
and housing.
CASSETTE: SRAM, 9 speed, 11x34t (low mileage rings)
CHAIN: Shimano HG-53
CRANKSET: Specialized Strongarm II, square taper
CHAINRINGS: 44Ax32Sx22S, 4 bolt, 104/64mm pattern,
steel chainring bolts
BOTTOM BRACKET: Shimano UN-25, 68mm shell, 113mm
spindle
PEDALS: Shimano M-505 SPD, or Wellgo platforms
(lightweight, and freshly cleaned/lubed with Park
lubricant). Choose either one.
RIMS: Mavic X139 Disc, 26", black
FRONT HUB: Specialized disc, 32 hole, loose ball
bearings, alloy Q/R
REAR HUB: Shimano M-475 disc, 32 hole, loose ball
bearings, alloy Q/R (Freshly cleaned/lubed with Park
Lubricant)
SPOKES: 1.8mm (15g) black stainless, brass nipples,
L260/R263mm front, L261/R260mm rear
Tires: WTB Velociraptor Front and Rear lightweight
"DNA" tires (lots of tread left). Very grippy and
light tires (not the cheaper wire beaded ones)
SADDLE: WTB Speed ProGel, recreational seat (very
comfortable). Less than 1 year old.
SEAT POST: Alloy, black, 30.9 (cut to fit me, 5'7")
SEAT BINDER: Alloy collar with Q/R, 34.9mm clamp I.D.,
black
Included: Chain Stay protector (neoprene w/ velco)
Bike sold as shown in these pictures. Feel free to
contact me to arrange a test ride.
http://s208.photobucket.com/al...5.jpg
http://s208.photobucket.com/al...6.jpg
http://s208.photobucket.com/al...7.jpg
http://s208.photobucket.com/al...8.jpg
http://s208.photobucket.com/al...9.jpg
http://s208.photobucket.com/al...0.jpg
http://s208.photobucket.com/al...1.jpg
http://s208.photobucket.com/al...2.jpg
http://s208.photobucket.com/al...3.jpg
http://s208.photobucket.com/al...4.jpg
Geometry: Size Small
Stand Over Height 688mm
Top Tube Length* 540mm
Head Tube Length 100mm
Head Angle 71 (about 69-70 with the Revelation Fork)
Seat Angle 69
Wheel Base 1035mm
Chain Stay Length 429mm
H/B Width 640mm
Crank Length 170mm
BB Height 318.5mm (slightly higher with Revelation
Fork)
* TT is measured horizontally from center of HT to
center of ST
Please contact me @
tk_1971@yahoo dot com
I'm located in So Cal, Pasadena.
the FSR XC.
water bottle bosses
6.0x1.25"
Key Features:
out)
-Manual lockout
pounds
25.4mm
top pull
and housing.
spindle
bearings, alloy Q/R
Lubricant)
black
Seat Angle 69
Wheel Base 1035mm
H/B Width 640mm
Crank Length 170mm
Fork)
center of ST
Please contact me @
jmk2888
Apr 22, 2008 12:09 PM
