wierd chirping sound
Old Apr 22, 2008 | 09:56 AM
davgonzalez1@aol.com's Avatar
Default wierd chirping sound
My 95 accord ex sedan just started making this noise that sounds a continuous bird chirping. Someone told me that it could be the belts. Its just really annoying and embarrasing having to drive around with that noise if you know what I mean.
Old Apr 22, 2008 | 10:22 AM
GhostAccord's Avatar
Default Re: wierd chirping sound (davgonzalez1@aol.com)
Do you have a question or are you just making a point that it's anoying?
If you are asking a question could you be more specific about what part of your car the the noise is coming from. Is it coming from under the hood, front or rear wheels.....
Did you check your belts yet?
Old Apr 22, 2008 | 11:33 AM
Brad_and_the_acc's Avatar
ok dude you need to give more info, is it an AUTO trans or a MANUAL???
If it is an MANUAL i would ask when does it make this "chirping" noise on or off the clutch??? could be clutch or throw-out bearing, and if its a AUTO then i would say check your own damn belts before you post a question and it could be other things to do some research on you own at least a little bit before you tell us how annoyed you are with a chirping sound (no info at all+++)( take this )
Old Apr 22, 2008 | 05:12 PM
lol, sorry guys. well my accord is a automatic and it sounds like its coming from the hood near the belts, and some more info, my back left wheel bearing is bad(my rim and tire can wiggle a bit and i hear a roar while on the road.
Old Apr 22, 2008 | 06:05 PM
Default Re: (davgonzalez1@aol.com)
If it chirps even while your not moving you should replace your accessory belts and while your at it get that wheel bearing replaced before your rear wheel falls off and you hurt someone
Old Apr 22, 2008 | 06:31 PM
Yes, it chirps while i am still(park) and also as i speed up the chirping speeds up too,
well, thanks and i will get the bearing fixed as soon as possible.
Old Apr 22, 2008 | 07:34 PM
FunnyVictor86's Avatar
like they said change the belts ... or if the belts arent that old and dont want to replace them just yet ... buy some belt quiet or whatever its called and spray them down ... its worth the shot ... sometimes it works sometimes it doesnt ...
Old Apr 22, 2008 | 07:56 PM
tpot90's Avatar
Default Re: (FunnyVictor86)
Change the accessory belt tensions. Maybe too tight, or too loose.
Old Apr 23, 2008 | 02:25 AM
well my belts all look pretty new, i will try the spray then, and if it persist, i will try to tighten or loosen, and if that doesn't work i will get new ones.
thx guys
Old Apr 23, 2008 | 06:34 AM
If you just want to test it befor you buy some "belt spray" what a couple of my buddys do is put some dish soap on their belts to get them to stop sqeaking. Its a "LITTLE" (ALOT) GHETTO, but it works
Old Apr 23, 2008 | 11:31 AM
JDM Panda's Avatar
also a bar of ivory or dail or w/e you household shower soap is you can put in the belt. just hold the bar next the the side of the belt or under it if possible. your belt might be glazed causeing this noise ( when your belts were put in they might have been tightened to tight).
kyle0209
Honda Civic (2001 - 2005)
Oct 20, 2016 01:59 AM
markman
May 19, 2012 06:56 PM
2Accords
Feb 19, 2008 02:25 PM
gizmotoy
11
Apr 3, 2006 09:13 AM
AcCoRd_HyBrId
May 10, 2002 09:37 AM
