Car turns off when i brake
i have a 95 SE lude and i been getting this problem just this week! whenever i drive and get to a stop, i put it to neutral and brake and out of no where the car turns off
!!! it turns off right before i stop and ofcourse after i put it in neutral. is it some wiring problem? or maybe uses up too much electricity ( i normally have my radio blasting? i cant seem to figure it out!!! help from you guys would be appreciated! thanks!!!
Sounds like it might be a vacuum problem if it only happens while braking. The brakes take a lot of vacuum. Have you looked for vacuum leaks. I had a similar problem on a different car and it turned out that the brake booster was leaking.
Hello,
Did you get that brake problem fixed ?
I have been plagued by a problem with my brakes for the last year and half.
Finally and after about $2000 I still have a mushy pedal.
Good pressure when the engine is off. Really soft and hits the floor when the vacuum kicks in.
I have changed everything except the booster.
And as you said the engine sounds like it is going to stall when I apply the brakes.
Thanks and waiting for your reply
Jay.
I have changed everything except the booster.And as you said the engine sounds like it is going to stall when I apply the brakes.
Jay.
Hello,
Jay.
Jay.
bullock
Nov 21, 2004 06:48 PM
