ECU cut off switch, better than fuel?
I'm going over the P13 pinout and I'm trying to decide if I should go for a ECU cut off switch instead of a fuel cutoff, or both? Anyway what circuits would be good to switch off? So far I'm looking at these...
A7------PGM-FI Main Relay coil
A21-----ICM
B9------Starter Cut Relay
Any suggestions?
A21-----ICM
Any suggestions?
My ecu always runs bad and studders and sometimes dies for a couple of days after I reset it. Even if I warm it up without driving for it to relearn ect. I would never do the ecu switch, but that's just me. The fuel switch would be a better option I think.
I didn't mean literally cut power to the ECU memory, I just meant chose one of the vital circuits from the ECU and add a switch to it. Most likely would be ICM, because the car would not start no matter what. I'm just worried that the fuel cutoff will give a thief too much time. I mean how far can you actually get on built up pressure in the lines?
jadugartir
17
Dec 18, 2006 05:38 AM
efboy
Audio / Security / Video
Sep 24, 2004 02:06 PM
Mugen Hamster
28
Mar 1, 2004 05:28 PM
