99 Civic SI B16A2 Swap
Old Apr 21, 2008 | 06:33 PM
jelatime's Avatar
New User
Default 99 Civic SI B16A2 Swap
I'm trying to swap out a shot B16A2 from my 99 Civic SI and have seen the JDM B16A SiR-II around online but can't find the specifics as to what else I need to buy to make it work in my current setup. Is the B16A SiR-II a direct swap for the B16A2. For example, is the OBD different? Do I need a new ECU? What all do I need to buy for this project?
Old Apr 21, 2008 | 06:40 PM
v8 integra's Avatar
Default Re: 99 Civic SI B16A2 Swap (jelatime)
jdm sir2 is obd1
Old Apr 21, 2008 | 06:43 PM
btk2334's Avatar
Default Re: 99 Civic SI B16A2 Swap (v8 integra)
yeah obd1 engine - obd2 car may require different harness... im not sure if the snesor's are different... yet if they are the same just reuse the old harness... because mechanically its the same... the elctronics make all the difference
jelatime's Avatar
New User
So what exactly does that entail - just a new wiring harness, new ECU...? What exactly does OBD describe...the sensor scheme on the engine (and the wiring connectors used) or is it more than that?
Old Apr 21, 2008 | 06:45 PM
v8 integra's Avatar
Default Re: 99 Civic SI B16A2 Swap (btk2334)
i belive u can use the same 99 harness...i think u just need to swap all the dizzy..sensors ect to the jdm motor..
Old Apr 21, 2008 | 06:50 PM
dj theoretic's Avatar
go to
http://hmotorsonline.com/shop/...gines
It's easy all you have to do is bolt it up. As for the engine harnest you will need a OBD1 harnest from a GSR (OBD1) or simply go to JHPusa or Password ... and search for a OBD2 to OBD1 (wire up) cant remember the name sorry, they have it for sure. Also if you use your harnest From your B16a2 it might give you engine check light because B16a Sir-2 did not come with a Knock Sensor because they are JDM ext... only the USDM ones came with it. good luck with ECL (knock sensor) I have it and its there for good untill i get my P30 worked on for that reason
Old Apr 21, 2008 | 06:54 PM
Frickr's Avatar
you will need to change out the oil pump to one that has a crankshaft position sensor also
Old Apr 21, 2008 | 06:58 PM
if you want to avoid probles because you are actually down grading from a obd2 to obd1, simply try getting a b16a2. it might cost a little more, but you will get no problems plus better milage. Make sure it's a obd2 b16a
Old Apr 21, 2008 | 07:03 PM
THIS SHOLD ANSWER YOUR QUESTION ON THE DEF... OF OBD
OBD-II Background
What is OBD-II?
Where'd it come from?
Why do we need it?
Does my car have OBD-II?
How do we measure OBD-II output?
What good does it do to measure OBD-II output?
Tell me about that "Check Engine Light".
OBD-II and your car's health
Proprietary Sensor Readings
OBD-II and performance tuning
What is OBD-II?
On-Board Diagnostic systems are in most cars and light trucks on the road today. During the '70s and early 1980's manufacturers started using electronic means to control engine functions and diagnose engine problems. This was primarily to meet EPA emission standards. Through the years on-board diagnostic systems have become more sophisticated. OBD-II, a new standard introduced in the mid-'90s, provides almost complete engine control and also monitors parts of the chassis, body and accessory devices, as well as the diagnostic control network of the car.
[Back to top]
To combat its smog problem in the LA basin, the State of California started requiring emission control systems on 1966 model cars. The federal government extended these controls nationwide in 1968.
Congress passed the Clean Air Act in 1970 and established the Environmental Protection Agency (EPA). This started a series of graduated emission standards and requirements for maintenance of vehicles for extended periods of time. To meet these standards, manufacturers turned to electronically controlled fuel feed and ignition systems. Sensors measured engine performance and adjusted the systems to provide minimum pollution. These sensors were also accessed to provide early diagnostic assistance.
At first there were few standards and each manufacturer had their own systems and signals. In 1988, the Society of Automotive Engineers (SAE) set a standard connector plug and set of diagnostic test signals. The EPA adapted most of their standards from the SAE on-board diagnostic programs and recommendations. OBD-II is an expanded set of standards and practices developed by SAE and adopted by the EPA and CARB (California Air Resources Board) for implementation by January 1, 1996.
[Back to top]
Why do we need it?
The Environmental Protection Agency has been charged with reducing "mobile emissions" from cars and trucks and given the power to require manufacturers to build cars which meet increasingly stiff emissions standards. The manufacturers must further maintain the emission standards of the cars for the useful life of the vehicle. OBD-II provides a universal inspection and diagnosis method to be sure the car is performing to OEM standards. While there is argument as to the exact standards and methodology employed, the fact is there is a need to reduce vehicle emitted pollution levels in our cities, and we have to live with these requirements.
[Back to top]
All cars built since January 1, 1996 have OBD-II systems. Manufacturers started incorporating OBD-II in various models as early as 1994. Some early OBD-II cars were not 100% compliant. <Click here> to see the dates OBD-II started being included on specific makes and models.
There are three basic OBD-II protocols in use, each with minor variations on the communication pattern between the on-board diagnostic computer and the scanner console or tool. While there have been some manufacturer changes between protocols in the past few years, as a rule of thumb, Chrysler products and all European and most Asian imports use ISO 9141 circuitry. GM cars and light trucks use SAE J1850 VPW (Variable Pulse Width Modulation), and Fords use SAE J1850 PWM (Pulse Width Modulation) communication patterns. <Click here> to see which cars use each system.
You may also tell which protocol is used on a specific automobile by examining the connector socket carefully. If the dash connector has a pin in the #7 position and no pin at #2 or #10, then the car has the ISO 9141 protocol. If no pin is present in the #7 position, the car uses an SAE protocol. If there are pins in positions #7 and #2 and/or #10, the car may use the ISO protocol.
While there are three OBD-II electrical connection protocols, the command set is fixed according to the SAE J1979 standard.
[Back to top]
Pre-OBD-II cars had connectors in various positions under the dashboard and under the hood. All OBD-II cars have a connector located in the passenger compartment easily accessible from the driver's seat. Check under the dash or behind or near the ashtray. A cable is plugged into the OBD-II J1962 connector and connected to AutoTap or another scan tool. AutoTap is available in PC/laptop or a Palm PDA versions. Other scantools on the market range from simple hand-held meters that display trouble codes, up to a large console computer-based unit costing thousands of dollars.
[Back to top]
OBD-II signals are most often sought in response to a "Check Engine Light" appearing on the dashboard or driveability problems experienced with the vehicle. The data provided by OBD-II can often pinpoint the specific component that has malfunctioned, saving substantial time and cost compared to guess-and-replace repairs. Scanning OBD-II signals can also provide valuable information on the condition of a used car purchase.
[Back to top]
The service industry calls the Check Engine light on your dash an "MIL" or Malfunction Indicator Light. It shows three different types of signals. Occasional flashes show momentary malfunctions. It stays on if the problem is of a more serious nature, affecting the emissions output or safety of the vehicle. A constantly flashing MIL is a sign of a major problem which can cause serious damage if the engine is not stopped immediately. In all cases a "freeze frame" of all sensor readings at the time is recorded in the central computer of the vehicle.
Hard failure signals caused by serious problems will cause the MIL to stay on any time the car is running until the problem is repaired and the MIL reset. Intermittent failures cause the MIL to light momentarily and they often go out before the problem is located. The freeze frame of the car's condition captured in the computer at the time of the malfunction can be very valuable in diagnosing these intermittent problems. However, in some cases if the car completes three driving cycles without a re-occurrence of the problem, the freeze frame will be erased.
[Back to top]
Because of their investment in the equipment required, most repair shops charge a fee, some-times substantial, to attach the scanning equipment and diagnose problems using the OBD-II system signals. Home mechanics and small shop technicians have been restricted from working with these signals by the cost and technical complexity of the equipment. With the introduction of more economical and user friendly scanning devices, it is now practical for almost anyone to access OBD-II signals and use them for their own testing and repairs.
Scanners vary greatly in their complexity. The best connect easily and use software to quickly and automatically call up the OBD-II information. They should have recording ability so that data can be collected during a test drive without distracting the technician driving the car. A system connecting to a laptop or desk top computer provides expanded memory for data and the ability to export data to a spreadsheet or graphing utility.
[Back to top]
Though not part of the EPA's OBD II standard, the diagnostic read-outs used by dealership technicians are also read through the OBD II connector. These service codes show you such things as knock sensor operation, FI pulse width, ignition voltage, individual cylinder misfires, transmission shift points and ABS brake condition. There can be over 300 readings available, depending on the vehicle manufacturer and model. Vehicles vary in the readings they will support. Scanners vary widely in the number of these signals that they can read. Some show just the basic OBD or OBD II signals, others show the full range of service codes.
[Back to top]
While the vast number of drivers want nothing more than dependable, economical transportation, many of us are looking to OBD-II for extra performance. Earlier on-board computer systems had chips that could be replaced to adjust engine parameters for extra speed and power. While the OBD-II systems are sealed and do not allow chip replacement, they do provide a real time data acquisition system that is useful to tuners.
Power loaders can actually reprogram the performance parameters of the OBD-II system to accommodate performance options. At the current time the number of models they can service is limited, but the range is being extended. Be sure the person doing your reprogramming keeps the car in compliance with EPA emission standards. As aftermarket manufacturers develop additional solutions, we will add their information to our links.
Old Apr 21, 2008 | 07:07 PM
jelatime's Avatar
New User
Default Re: (dj theoretic)
Thanks for all of the info. Looking around for a B16A2 but they are few and far between...
Brettw
Feb 6, 2014 09:15 AM
v-tec maz
Dec 25, 2005 04:28 PM
97mini-me
May 24, 2004 05:22 PM
