ls swap in 91 crx harness problems
Old Apr 21, 2008 | 09:29 AM
dustins-lost-cause's Avatar
Default ls swap in 91 crx harness problems
im doing a ls swap in my crx im using my stock harness the problem is that one of the plugs are deferent on my distributer i would just swap out the plug but it has 7 wires compared to my crx harness has 5 what should i do
Old Apr 21, 2008 | 09:46 AM
thevtecnician's Avatar
Default Re: ls swap in 91 crx harness problems (dustins-lost-cause)
First off what model crx do you have? I actually am using a 88-91 si sohc dizzy on my da integra but only one bolt hole lines up. You could do that if you wanted I guess
Old Apr 21, 2008 | 09:56 AM
jlicrx's Avatar
sounds like you have a DX, LX or STD model car - when converting it to MPFI, you have to add 2 wires from the ECU to the distributor for the Cylinder sensor - these are the other 2 wires that go into the round 7-wire connector that you need to swap onto the harness to match the connector on the distributor
Old Apr 21, 2008 | 10:09 AM
its an si harness i would do the dizzy swap but all i have is zc dizzy and dose not work at all
Old Apr 21, 2008 | 10:27 AM
jlicrx's Avatar
o.k. - sounds like you may have a harness that was converted to run the DOHC ZC - the DOHC ZC uses a square 5-wire connector and has the other 2 wires running to the Cylinder sensor on the exhaust camshaft - the cylinder sensor wires are blue with green stripe and blue with yellow stripe - do you have those 2 wires coming out of the harness at the distributor connector?
Old Apr 21, 2008 | 10:35 AM
Default Re: ls swap in 91 crx harness problems (jlicrx)
i have a distr kink dizzy but it has a blue ... and next to it it has blue with yellow strip
king not kink
Old Apr 21, 2008 | 10:45 AM
jlicrx's Avatar
blue on distributor king is same as blue/green on OEM - did you find the wires in the harness?
Old Apr 21, 2008 | 10:59 AM
yup and now i know sadaring now i thank you for the help
unisonicz
Feb 10, 2016 06:10 AM
buckweeb101
Feb 6, 2013 12:34 PM
turboef90
Jan 29, 2013 12:26 PM
shortA25
Jan 21, 2011 12:35 PM
juanb
Oct 27, 2004 07:47 PM
