Part numbers for crank case ventilation ports
What are the part numbers for the barbs that screw into the holes at the back of the block when the two plugs are removed? I've had a look through the threads in the sticky, but the pic with the part numbers in is just showing a red X.
http://www.hondaautomotivepart...L+PAN
pretty sure its #2 & #17 , http://www.sonshondaparts.com no longer shows part numbers or I would give them to you.
I dont think Honda dealers ship over seas but I could be wrong.I do know Tony1 on here sells them in a kit on his website
Thanks guys, I can order them from my local Honda dealer, I just need the Honda part numbers....
EDIT: After some googling I've found the part number for the barbs: 11107-PK2-003.
Still no joy on the washers......
Modified by DreXeL_UK at 11:19 AM 4/21/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues »</TD></TR><TR><TD CLASS="quote">I dont think Honda dealers ship over seas but I could be wrong.I do know Tony1 on here sells them in a kit on his website
yes but his kit requires you to use AN fittings or an AN to barb adaptor, these Honda fittings you just slip the hose over and clamp.
</TD></TR></TABLE>yes but his kit requires you to use AN fittings or an AN to barb adaptor, these Honda fittings you just slip the hose over and clamp.
Here you go, you can find the washer part numbers in this thread.
https://honda-tech.com/zerothread?id=1490117
Ahknodd
Sep 13, 2006 05:29 PM
VtecAdil
Dec 31, 2005 04:05 PM
dingusjt
Oct 8, 2003 06:27 AM
