NEED HELP!!!! staling problems
i got a 03 ex i took out my air filter and now its stalling i put it back in nd its still stalling and now a check engine light came on. wut should i do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMike418 »</TD></TR><TR><TD CLASS="quote">i got a 03 ex i took out my air filter and now its stalling i put it back in nd its still stalling and now a check engine light came on. wut should i do</TD></TR></TABLE>
You should find out what's causing the CEL, by getting it scanned.
all you did was replace the air filter? did you drop anything into the air box? or did you remove the air filter and run the car that way? if you ran the car w/out a filter, you could have sucked something into the engine...
get the code read from the car...
if all you did was replace the air filter, i guess you could try disconnecting the battery then reconnect it again to get the car to relearn the idle speed
Want2race
12
Dec 10, 2005 04:26 PM
